Smart camera system for vision-guided robotics
ABB Robotics' Integrated Vision works with PC-based ABB RobotStudio to provide a platform for creating vision-guided robotic applications.
December 2, 2013
ABB Robotics has introduced Integrated Vision, a powerful smart camera system that makes vision-guided robotics applications faster and easier to deploy than ever before. Using 2D vision guidance, ABB Integrated Vision allows manufacturers to:  track products more accurately, improve supply chain management, improve quality, troubleshoot challenging lines and processes, and significantly expand their use of robotic automation. Taken together, the advantages of vision-guided robotics can significantly improve a company’s bottom line, saving time, money, and other valuable resources.
ABB Integrated Vision features sophisticated imaging technologies such as the patented PatMax algorithm for advanced part location. The result is robust inspection, defect detection, guidance, alignment, and measurement, all critical to ensuring that manufactured products meet the highest possible quality standards.
The technology is easy to setup, deploy and maintain. RobotStudio, ABB’s powerfully simple PC-based programming tool, provides the platform for creating vision tasks quickly and easily. Operators can select features, set parameters and operate under real world conditions from a library of common vision applications. The smart camera offers the widest range of built-in communication protocols that interface directly with the robot, helping complete programming and set-up in approximately 25% of the traditional time.
ABB Robotics
Industrial Robot Supplier and Manufacturer | ABB Robotics
var jsLibs = [];
function isBackend() { return document.getElementsByTagName(“body”)[0].className.match(/sfPageEditor/) && (typeof requirejs !== ‘undefined’); }
function widgetInit(widget, callback) { if (isBackend()) { callback = callback || function () { }; require([widget], function () { callback(); }); } }
function dragDropCallback(callback) { if (isBackend()) { callback(); } }
var _gaq = _gaq || [];
function TimeTracker(a, b, c) { return this.MAX_TIME = 6e5, this.category = a, this.variable = b, this.label = c ? c : void 0, this.startTime, this.elapsedTime, this.isDebug = !0, this } TimeTracker.prototype = { startTime: function () { return this.startTime = (new Date).getTime(), this }, endTime: function () { return this.elapsedTime = (new Date).getTime() – this.startTime, this }, debug: function (a) { return this.isDebug = void 0 == a ? !0 : a, this }, send: function (a, b) { if (a = a || this.variable, b = b || this.label, 0 < this.elapsedTime && this.elapsedTime < this.MAX_TIME) { var c = ["_trackTiming", this.category, a, this.elapsedTime, b]; this.isDebug && (c.push(100), window.console && window.console.log && console.log(c)), window._gaq.push(c) } return this } }, window.tt = new TimeTracker("Page", "General Timing"), window.tt.startTime();
window.atctSettings = {"enableCart":true,"showCartCookieName":"showCart","host":"https://ace.abb.com","getCartOnInit":false,"previewCss":"https://www.abb.com/Sitefinity/WebsiteTemplates/AbbBranding/App_Scripts/requirejs-libs/cart/cartpreviews.css"};
window.seoSettings = {"enableBreadcrumbSnippet":true};
.slideDownMenu.sf_colsOut.sf_1col_1_100 {
float: right;
header.abb-page__header.abb-page__header–sticky {
z-index: 9!important;
a.module-heading__link.module-heading__link–is-external {
z-index: 1;
}bazadebezolkohpepadr=”1204508496″
The world's most remote robot
ABB's technological solution for replanting the Amazon
/* CSS for main container */
.backgroundvideo_mainconteiner {
position: relative;
/* CSS for Dark Mask */
.backgroundvideo_mask {
filter: brightness(0.5);
/* CSS for Gradient Mask*/
.backgroundvideo_gradient::after {
content: “”;
position: absolute;
left: 0;
top: 0;
width: 100%;
height: 99%;
display: inline-block;
background: -moz-linear-gradient(63.75deg, rgba(0, 0, 0, 0.8) 0, rgba(0, 0, 0, 0.0001) 100%);
background: -webkit-linear-gradient(63.75deg, rgba(0, 0, 0, 0.8) 0, rgba(0, 0, 0, 0.0001) 100%);
background: -o-linear-gradient(63.75deg, rgba(0, 0, 0, 0.8) 0, rgba(0, 0, 0, 0.0001) 100%);
background: -ms-linear-gradient(63.75deg, rgba(0, 0, 0, 0.8) 0, rgba(0, 0, 0, 0.0001) 100%);
background: linear-gradient(63.75deg, rgba(0, 0, 0, 0.8) 0, rgba(0, 0, 0, 0.0001) 100%);
ABB Robotics
jsLibs.push(“layout8_4”);
ABB Robotics as one of the world’s leading robotics and machine automation suppliers is the only company with a comprehensive and integrated portfolio covering robots, AMRs and machine automation solutions – designed and orchestrated by our value-creating software. ABB Robotics employs approximately 11,000 people at over 100 locations in more than 50 countries.
.descriptionText {
display: block;
clear: both;
.linkText {
clear: both;
.abbButton.gradientHeadlineColors.red.text-right {
float: right;
.abbButton.gradientHeadlineColors.red.text-left {
float: left;
.abbButton.gradientHeadlineColors.gray.text-right {
float: right;
.abbButton.gradientHeadlineColors.gray.text-left {
float: left;
.normal.text-left {
float: left;
.normal.text-right {
float: right;
Our portfolio
jsLibs.push(“expandable”);
widgetInit(“expandable”, function () {
initExpandableLayout();
News and highlights
jsLibs.push(“newimagegalleryinitnew”);
widgetInit(“newimagegalleryinitnew”, function () {
// if backend, turn off carrousel so you can drag/drop tiles inside layout
if ($(‘body’).attr(‘class’).indexOf(‘sfPageEditor’) != -1) {
$(‘.rs-carousel’).removeClass(‘rs-carousel’);
.descriptionText {
display: block;
clear: both;
.linkText {
clear: both;
float: right;
float: left;
float: right;
float: left;
.normal.text-left {
float: left;
float: right;
Industries we serve
dragDropCallback(function () {
rememberContainingLayout();
How we help our customers
CSS Flexbox Cards</a> </p> <p>– See more <i>Control Engineering</i> <a href="https://www.controleng.com/mechatronics-motion-control/robotics/" target="cfeTarget" rel="noopener">robotics products</a>.</p> <p class="contribute-link-container">Do you have experience and expertise with the topics mentioned in this content? You should consider contributing to our CFE Media editorial team and getting the recognition you and your company deserve. Click <a href="https://controleng.dragonforms.com/loading.do?omedasite=brandContributor&pk=CE" target="_blank" title="How to Contribute" alt="How to Contribute">here</a> to start this process.</p> </div> </div> <div class="relatedArticles"> <div class="relatedArticles__title">Related Articles</div> <ul class="relatedArticles__list"> <li> <a href="https://www.controleng.com/articles/universal-light-curtain-light-grid/"> Universal light curtain, light grid </a> </li> <li> <a href="https://www.controleng.com/articles/machine-tending-software/"> Machine tending software </a> </li> <li> <a href="https://www.controleng.com/articles/robot-designed-to-handle-payloads-up-to-8-kg-at-100-cycles-per-minute/"> Robot designed to handle payloads up to 8 kg at 100 cycles per minute </a> </li> </ul> </div> <div class="divider divider--default"> <hr> </div> <div id="personalization-under-content"></div> <section class="frame__full product-home--container"> <div class="newProductList no-dotted-line"> <div class="nav-search--container full-search-bar"> <a class="npe-logo--header" href="https://gspplatform.cfemedia.com/pe/home" target="_blank"> <img alt="New Products for Engineers" src="//d3mm496e6885mw.cloudfront.net/NP4E_2019/Images/logos/np-Logo.svg"> </a> <div> <div class="forest"> Search Products And Discover New Innovations In Your Industry </div> <div class="bar-wrapper"> <form class="product-search--form" onsubmit="document.getElementById( 'middleSearchBox' ).value.trim() ? window.open('https://gspplatform.cfemedia.com/pe/search?widgetPosition=contentbody&externalPageUrl='+window.btoa( document.location.href )+'&externalPageType=home&externalPageTitle='+document.getElementsByTagName('title').valueOf()[0].innerText.replace(/[^a-zA-Z ]/g, '')+'&keywords=' + document.getElementById( 'middleSearchBox' ).value, '_blank') : window.open('https://gspplatform.cfemedia.com/pe/home', '_blank'); return false"> <input id="middleSearchBox" class="search-box" type="text"> <button class="search nav-search--btn" type="submit"> <span class="mat-button-wrapper"> SEARCH </span> <div class="mat-button-ripple mat-ripple"></div> <div class="mat-button-focus-overlay"></div> </button> </form> <mat-autocomplete class="mat-autocomplete"></mat-autocomplete> </div> </div> </div> <!--<div class="newProductList__content new-product-widget-container"> </div>--> </div> </section> <div id="personalization-under-content"></div> </section> </section> <aside class="frame__secondary"> <div id="custom_html-9" class="widget_text widget widget_custom_html"><div class="textwidget custom-html-widget"><div id="personalization"> </div></div></div> <div class="advertisement advertisement-desktop-300x600"> <div id="article-sidebar-skyscraper-ad-1" style="min-width: 160px; min-height: 250px;"></div> </div> <div id="custom_html-19" class="widget_text widget widget_custom_html"><div class="textwidget custom-html-widget"><div id="personalization"> </div></div></div> <div class="subscribePromo"> <div class="subscribePromo__content"> <div class="subscribePromo__logo"><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 164 50"> <path fill="#0872B9" d="M39.1 19.9C37 24.7 31.9 27.7 26.8 27.7 19.1 27.7 12.9 21.4 12.9 14.1 12.9 6.9 19 .7 26.7.7 31.1.7 36.7 2.9 39.3 8.6L33.7 8.6C31.8 6.5 29.5 5.2 26.6 5.2 22.3 5.2 17.9 9 17.9 14.2 17.9 19.1 22 23.3 26.8 23.3 30.4 23.3 32.3 21.3 33.5 20L39.1 20 39.1 19.9zM49.6 6.4C55.6 6.4 60.6 11 60.6 17.1 60.6 22.9 55.6 27.6 49.6 27.6 43.5 27.6 38.6 22.9 38.6 17.1 38.6 11 43.6 6.4 49.6 6.4zM49.6 23.7C53.6 23.7 56.7 20.6 56.7 17 56.7 13.3 53.5 10.3 49.6 10.3 45.7 10.3 42.5 13.3 42.5 17 42.5 20.6 45.6 23.7 49.6 23.7zM79.5 6.8L87.4 6.9 87.4 10.4 83.5 10.4 83.5 27.2 79.5 27.2 79.5 6.8zM78.4 6.8L74.5 6.8 70.5 6.8 70.5 10.3 74.5 10.3 74.5 21.6 74.4 21.6 65.7 6.8 61.3 6.8 61.3 27.2 65.2 27.2 65.2 12.4 65.3 12.4 74.1 27.2 78.5 27.2 78.4 6.8zM88.2 6.8L94.7 6.8C97.1 6.8 98.6 7.2 99.8 8.2 101 9.1 102.3 10.8 102.3 13.1 102.3 14.4 101.8 16.6 100.3 18 99 19.2 97.8 19.4 96.8 19.7L102.5 27.2 97.8 27.2 92.2 19.4 92.1 19.4 92.1 27.2 88.2 27.2 88.2 6.8zM92.1 16.6L94.6 16.6C97.8 16.6 98.4 14.5 98.4 13.5 98.4 12.4 97.7 10.4 94.6 10.4L92.1 10.4 92.1 16.6zM113.3 6.4C119.3 6.4 124.3 11 124.3 17.1 124.3 22.9 119.3 27.6 113.3 27.6 107.2 27.6 102.3 22.9 102.3 17.1 102.3 11 107.3 6.4 113.3 6.4zM113.3 23.7C117.3 23.7 120.4 20.6 120.4 17 120.4 13.3 117.2 10.3 113.3 10.3 109.3 10.3 106.2 13.3 106.2 17 106.2 20.6 109.3 23.7 113.3 23.7zM125.2 6.8L129.1 6.8 129.1 23.6 135.5 23.6 135.5 27.1 125.1 27.1 125.1 6.8 125.2 6.8zM.6 22.9L15.1 22.9 15.1 27.4 5.6 27.4 5.6 33.8 14.7 33.8 14.7 38.3 5.6 38.3 5.6 44.4 15.1 44.4 15.1 48.9.6 48.9.6 22.9zM15.7 28.5L20.2 28.5 28.9 43.3 29 43.3 29 28.5 32.9 28.5 32.9 48.9 28.5 48.9 19.7 34 19.6 34 19.6 48.8 15.7 48.8 15.7 28.5zM42.2 38.5L56 38.5 56 38.9C56 44.7 50.7 49.2 44.8 49.2 38.8 49.2 33.4 44.7 33.4 38.6 33.4 32.6 38.7 28 44.6 28 49.9 28 53.8 31.5 54.8 34.4L50.1 34.4C49.2 33.1 47.2 31.7 44.5 31.7 39.7 31.7 37.3 35.5 37.3 38.6 37.3 41.6 39.7 45.5 44.7 45.5 47.3 45.5 49.7 44.3 50.9 41.9L42.1 41.9 42.1 38.5 42.2 38.5zM56.4 28.5L60.3 28.5 60.3 48.9 56.4 48.9 56.4 28.5zM61.3 28.5L65.8 28.5 74.5 43.3 74.6 43.3 74.6 28.5 78.5 28.5 78.5 48.9 74 48.9 65.2 34 65.1 34 65.1 48.8 61.2 48.8 61.2 28.5 61.3 28.5zM79.5 28.5L90.9 28.5 90.9 32 83.5 32 83.5 37 90.6 37 90.6 40.5 83.5 40.5 83.5 45.3 90.9 45.3 90.9 48.8 79.5 48.8 79.5 28.5zM91.8 28.5L103.2 28.5 103.2 32 95.8 32 95.8 37 102.9 37 102.9 40.5 95.8 40.5 95.8 45.3 103.2 45.3 103.2 48.8 91.8 48.8 91.8 28.5zM104 28.5L110.5 28.5C112.9 28.5 114.4 28.9 115.6 29.9 116.8 30.8 118.1 32.5 118.1 34.8 118.1 36.1 117.6 38.3 116.1 39.7 114.8 40.9 113.6 41.1 112.6 41.4L118.3 48.9 113.6 48.9 108 41.1 107.9 41.1 107.9 48.9 104 48.9 104 28.5zM107.9 38.2L110.4 38.2C113.6 38.2 114.2 36.1 114.2 35.1 114.2 34 113.5 32 110.4 32L107.9 32 107.9 38.2zM118.3 28.5L122.2 28.5 122.2 48.9 118.3 48.9 118.3 28.5zM123.2 28.5L127.7 28.5 136.4 43.3 136.5 43.3 136.5 28.5 140.4 28.5 140.4 48.9 136 48.9 127.1 34 127 34 127 48.8 123.1 48.8 123.1 28.5 123.2 28.5zM149.7 38.5L163.5 38.5 163.5 38.9C163.5 44.7 158.2 49.2 152.3 49.2 146.3 49.2 140.9 44.7 140.9 38.6 140.9 32.6 146.2 28 152.1 28 157.4 28 161.3 31.5 162.3 34.4L157.6 34.4C156.7 33.1 154.7 31.7 152 31.7 147.2 31.7 144.8 35.5 144.8 38.6 144.8 41.6 147.2 45.5 152.2 45.5 154.8 45.5 157.2 44.3 158.4 41.9L149.6 41.9 149.6 38.5 149.7 38.5zM160.4 48.1C160.4 47.4 161 46.8 161.7 46.8 162.4 46.8 163 47.3 163 48.1 163 48.8 162.4 49.4 161.7 49.4 161 49.3 160.4 48.8 160.4 48.1zM161.7 49.1C162.3 49.1 162.7 48.7 162.7 48.1 162.7 47.5 162.3 47.1 161.7 47.1 161.1 47.1 160.7 47.5 160.7 48.1 160.7 48.7 161.1 49.1 161.7 49.1zM161.5 48.8L161.3 48.8 161.3 47.4 161.9 47.4C162.2 47.4 162.4 47.5 162.4 47.8 162.4 48.1 162.2 48.2 162 48.2L162.4 48.8 162.2 48.8 161.8 48.2 161.5 48.2 161.5 48.8zM161.7 48C161.9 48 162.1 48 162.1 47.8 162.1 47.6 161.9 47.6 161.8 47.6L161.5 47.6 161.5 48 161.7 48z" /> </svg> </div> <div class="subscribePromo__title">Magazines and Newsletters</div> <a class="subscribePromo__link" href="https://www.controleng.com/subscribe">Subscribe</a> <div class="subscribePromo__tagline">Sign Up Today!</div> </div> </div> <div id="custom_html-25" class="widget_text widget widget_custom_html"><div class="textwidget custom-html-widget"><div class="podcast"> <a href="https://www.controleng.com/podcast-2/"><img src="https://www.controleng.com/wp-content/uploads/sites/2/2024/01/CE_sidebar_1.png" alt="podcast-ad" style="width:100%;"/></a> </div></div></div> <div class="advertisement advertisement-desktop-300x400"> <div id="article-sidebar-ebook-ad-1" style="min-width: 300px; min-height: 400px;"></div> </div> <div class="widget postsWidget"> <div class="widget__title">Related Content</div> <div class="widget__content"> <div class="postCardList"> <div class="postCard full-card"> <div class="postCard__content"> <div class="postCard__title"> <a href="https://www.controleng.com/articles/how-to-integrate-smarter-motion-controls-into-machine-designs/">How to integrate smarter motion controls into machine designs</a> </div> <div class="postCard__author"> Mark T. Hoske </div> </div> </div> <div class="postCard full-card"> <div class="postCard__content"> <div class="postCard__title"> <a href="https://www.controleng.com/articles/five-advances-in-motion-control-communications-design-to-ease-automation-use/">Five advances in motion control, communications, design to ease automation use</a> </div> <div class="postCard__author"> Mark T. Hoske </div> </div> </div> <div class="postCard full-card"> <div class="postCard__content"> <div class="postCard__title"> <a href="https://www.controleng.com/articles/motion-control-ease-of-use-sustainability-pack-expo-las-vegas-2023/">Motion control, ease of use, sustainability: Pack Expo Las Vegas 2023</a> </div> <div class="postCard__author"> Mark T. Hoske </div> </div> </div> <div class="postCard full-card"> <div class="postCard__content"> <div class="postCard__title"> <a href="https://www.controleng.com/articles/how-electrification-of-linear-actuators-improve-material-handling-automation/">How electrification of linear actuators improve material handling automation</a> </div> <div class="postCard__author"> Travis Gilmer </div> </div> </div> <div class="postCard full-card"> <div class="postCard__content"> <div class="postCard__title"> <a href="https://www.controleng.com/articles/advancing-motion-control-applications-with-the-right-drives-technology/">Advancing motion control applications with the right drives, technology</a> </div> <div class="postCard__author"> Thomas Burke </div> </div> </div> <div class="postCard full-card"> <div class="postCard__content"> <div class="postCard__title"> <a href="https://www.controleng.com/articles/motion-control-market-showing-steady-growth-in-2023/">Motion control market showing steady growth in 2023</a> </div> <div class="postCard__author"> Interact Analysis </div> </div> </div> <div class="postCard full-card"> <div class="postCard__content"> <div class="postCard__title"> <a href="https://www.controleng.com/articles/cnc-robots-industrial-training-help-freedman-seating/">CNC, robots, industrial training help Freedman Seating</a> </div> <div class="postCard__author"> Mark T. Hoske </div> </div> </div> </div> </div> </div> <div class="advertisement advertisement-desktop-300x250"> <div id="article-sidebar-boombox-ad-1" style="min-width: 300px; min-height: 250px;"></div> </div> <div class="widget postsWidget"> <div class="widget__title">Recent Products</div> <div class="widget__content"> <div class="postCardList"> <div class="postCard full-card"> <div class="postCard__content"> <div class="postCard__title"> <a href="https://www.controleng.com/products/low-cost-motion-control-offered-with-click-plus-plcs/">Low-Cost Motion Control Offered with CLICK PLUS PLCs</a> </div> <div class="postCard__author"> AutomationDirect </div> </div> </div> <div class="postCard full-card"> <div class="postCard__content"> <div class="postCard__title"> <a href="https://www.controleng.com/products/amt11a-series-incremental-encoder/">AMT11A Series Incremental Encoder</a> </div> <div class="postCard__author"> CUI Devices </div> </div> </div> <div class="postCard full-card"> <div class="postCard__content"> <div class="postCard__title"> <a href="https://www.controleng.com/products/nc-cut-off-machine-2/">NC Cut Off Machine</a> </div> <div class="postCard__author"> Hebei Lover Import and Export Trade Co., Ltd </div> </div> </div> <div class="postCard full-card"> <div class="postCard__content"> <div class="postCard__title"> <a href="https://www.controleng.com/products/powered-hub/">Powered Hub</a> </div> <div class="postCard__author"> One Motion </div> </div> </div> <div class="postCard full-card"> <div class="postCard__content"> <div class="postCard__title"> <a href="https://www.controleng.com/products/cl26-series-steel-disc-coupling-with-locking-assembly/">CL26 Series steel disc coupling with locking assembly</a> </div> <div class="postCard__author"> Candy Controls </div> </div> </div> </div> </div> </div> <div class="advertisement advertisement-desktop-300x600"> <div id="article-sidebar-skyscraper-ad-2" style="min-width: 160px; min-height: 250px;"></div> </div> <div id="custom_html-5" class="widget_text widget widget_custom_html"><div class="textwidget custom-html-widget"><div id="personalization-marketing"></div></div></div> </aside> </div> </main> <script nitro-exclude> document.cookie = 'nitroCachedPage=' + (!window.NITROPACK_STATE ? '0' : '1') + '; path=/; SameSite=Lax'; </script> <script nitro-exclude> if (!window.NITROPACK_STATE || window.NITROPACK_STATE != 'FRESH') { var proxyPurgeOnly = 0; if (typeof navigator.sendBeacon !== 'undefined') { var nitroData = new FormData(); nitroData.append('nitroBeaconUrl', 'aHR0cHM6Ly93d3cuY29udHJvbGVuZy5jb20vYXJ0aWNsZXMvc21hcnQtY2FtZXJhLXN5c3RlbS1mb3ItdmlzaW9uLWd1aWRlZC1yb2JvdGljcy8='); nitroData.append('nitroBeaconCookies', 'W10='); nitroData.append('nitroBeaconHash', '96056c49ac97489bcf983d0e0b6f190722071c4586d50bec20077cb1452dcf2facaf47a4dfa615d0846920eade7d6571802d2a472131bb26e464b57c502c6507'); nitroData.append('proxyPurgeOnly', ''); nitroData.append('layout', 'post'); navigator.sendBeacon(location.href, nitroData); } else { var xhr = new XMLHttpRequest(); xhr.open('POST', location.href, true); xhr.setRequestHeader('Content-Type', 'application/x-www-form-urlencoded'); xhr.send('nitroBeaconUrl=aHR0cHM6Ly93d3cuY29udHJvbGVuZy5jb20vYXJ0aWNsZXMvc21hcnQtY2FtZXJhLXN5c3RlbS1mb3ItdmlzaW9uLWd1aWRlZC1yb2JvdGljcy8=&nitroBeaconCookies=W10=&nitroBeaconHash=96056c49ac97489bcf983d0e0b6f190722071c4586d50bec20077cb1452dcf2facaf47a4dfa615d0846920eade7d6571802d2a472131bb26e464b57c502c6507&proxyPurgeOnly=&layout=post'); } } </script> <script type="text/javascript"> // production olytics 3.0, uses PROD_OID window.olytics||(window.olytics=[]),window.olytics.methods=["fire","confirm"],window.olytics.factory=function(i){return function(){var t=Array.prototype.slice.call(arguments);return t.unshift(i),window.olytics.push(t),window.olytics}};for(var i=0;i<window.olytics.methods.length;i++){var method=window.olytics.methods[i];window.olytics[method]=window.olytics.factory(method)}olytics.load=function(i){if(!document.getElementById("olyticsImport")){window.a=window.olytics;var t=document.createElement("script");t.async=!0,t.id="olyticsImport",t.type="text/javascript";var o="";void 0!==i&&void 0!==i.oid&&(o=i.oid),t.setAttribute("data-oid",o),t.src="https://olytics.omeda.com/olytics/js/v3/p/olytics.min.js",t.addEventListener("load",function(t){for(olytics.initialize({Olytics:i});window.a.length>0;){var o=window.a.shift(),s=o.shift();olytics[s]&&olytics[s].apply(olytics,o)}},!1);var s=document.getElementsByTagName("script")[0];s.parentNode.insertBefore(t,s)}},olytics.load({oid:"9f8c627c88754b969341f7b0625558ae"}); </script> <script type="text/javascript"> olytics.fire({ // add behavior id and additional data to javascript object taxonomy: "CE DISCRETE MFG PRODUCTS,Machine Control,New Products,Sensors,Syndication: Discrete Manufacturing,Syndication: Discrete Sensors (Proximity| Presence| Load Cells| Limit Switches| Torque| Encoders)| Machine Vision,Syndication: Machine and Motion Control (CNC| Pneumatic| Hydraulic| Electric),Syndication: Motors and Drives (VFD| Inverters| Servo| Torque Converters),SyndicationIndustry: Material Handling (Including Robotics| Conveyors| And Elevators),SyndicationSource: CFE Media (in-house),SyndicationTopic: Discrete Manufacturing,SyndicationType: Product Release", // add behavior id and additional data to javascript object tag: "ABB Robotics,Control Engineering,discrete manufacturing,Integrated Vision,machine control,motion control,new products,robot vision system,robotic vision system,robotics,sensors,vision guided robotics,vision-guided robots", // add behavior id and additional data to javascript object category: "CNC| Motion Control", // add behavior id and additional data to javascript object section: "Article", // add behavior id and additional data to javascript object behaviorId: "2672C9123356A8B", // add behavior id and additional data to javascript object ownTheTopic: "Motors & Drives Efficiency", PageURL: window.location.href }); </script> <div id="personalization-footer"></div> <footer class="siteFooter"> <nav class="siteFooter__socialMenu"> <ul> <li data-service="twitter"> <a href="https://twitter.com/controlengtips"> <svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 64 64"> <path d="M64,12.0527527 C62.2221666,14.6878338 59.9971231,16.9916398 57.4254545,18.8600254 C57.4254545,19.4806315 57.4254545,20.0430557 57.4254545,20.5472982 C57.5050694,29.8582371 54.0660148,38.8558845 47.7963636,45.7400254 C40.871195,53.7659436 30.6977829,58.2435273 20.1018182,57.9291164 C12.9644711,57.9633001 5.97437943,55.8996551 0,51.9945709 C1.03924191,52.1644185 2.08905856,52.2616237 3.14181818,52.28548 C9.08314034,52.2975544 14.8432446,50.2403743 19.4327273,46.4672982 C16.6625255,46.4678997 13.9708587,45.546797 11.7818182,43.8491164 C9.59347764,42.2295453 7.97425072,39.9585541 7.15636364,37.3618436 C7.97170245,37.5152457 8.79944788,37.5931511 9.62909091,37.5945709 C10.8064704,37.5968708 11.9794137,37.4502528 13.12,37.1582073 C7.08658091,35.9131352 2.79596335,30.5468073 2.90909091,24.3872982 L2.90909091,24.2127527 C4.73211485,25.1081332 6.70435735,25.6603611 8.72727273,25.8418436 C5.00519361,23.4809284 2.79616675,19.339003 2.90909091,14.9327527 C2.87516674,12.6078236 3.46805228,10.3166727 4.62545455,8.30002544 C11.1453312,16.650819 21.0330816,21.6799334 31.6218182,22.0309345 C31.419911,21.0740937 31.312727,20.0996942 31.3018182,19.1218436 C31.3018182,11.8758677 37.1758423,6.00184363 44.4218182,6.00184363 C48.0635145,5.93958628 51.5538916,7.45668027 53.9927273,10.1618436 C56.9404944,9.57275967 59.7647975,8.48043338 62.3418182,6.93275272 C61.3961078,10.0151505 59.3170117,12.6244161 56.5236364,14.2345709 C59.1085486,13.8745089 61.6271573,13.1395063 64,12.0527527 Z"/> </svg> <span class="screen-reader-text">Twitter</span> </a> </li> <li data-service="facebook"> <a href="https://www.facebook.com/ControlEngineeringMagazine"> <svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 64 64"> <path d="M36.84,64 L23.532,64 L23.532,33.616 L16,33.616 L16,22.59 L23.532,22.59 L23.532,14.526 C23.532,5.652 27.428,0 37.916,0 L46.658,0 L46.658,11.294 L41.144,11.294 C36.978,11.294 36.706,12.776 36.706,15.598 L36.706,22.59 L46.658,22.59 L45.448,33.482 L36.706,33.482 L36.706,64 L36.84,64 Z"/> </svg> <span class="screen-reader-text">Facebook</span> </a> </li> <li data-service="slideshare"> <a href="https://www.slideshare.net/ControlEng"> <svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 64 64"> <g fill="none" fill-rule="evenodd"> <path fill="#000" fill-rule="nonzero" d="M61.1076177,30.347102 C60.8620667,30.5227755 60.6171687,30.6893061 60.3729238,30.8551837 L60.3729238,6.19102041 C60.3729238,2.76702041 57.7979034,0 54.6285973,0 L9.94745441,0 C6.77880135,0 4.20378094,2.76702041 4.20378094,6.19102041 L4.20378094,30.8780408 C3.94908707,30.7049796 3.69308707,30.5306122 3.43643401,30.347102 C1.53276054,29.0187755 0.284760536,30.827102 1.45178094,32.555102 C3.72378094,35.338449 8.04312788,38.795102 14.6658218,41.514449 C7.65912788,65.3838367 31.7681891,69.1748571 31.3992095,56.9364898 C31.3992095,57.1637551 31.4129238,49.9898776 31.4227197,44.9025306 C32.0561891,45.0514286 32.6047605,45.1970612 33.121332,45.3244082 C33.1317809,50.3764898 33.143536,57.1572245 33.143536,56.9364898 C32.7752095,69.1748571 56.9005973,65.3838367 49.8775769,41.514449 C56.5009238,38.795102 60.8209238,35.338449 63.0909646,32.555102 C64.2592911,30.8277551 63.0119442,29.0194286 61.1076177,30.347102 Z M37.3198626,36.427102 C34.3706381,36.2782041 33.2780667,37.546449 33.132434,39.5010612 C32.4225565,38.996898 31.6976585,38.3967347 30.9538218,37.706449 C30.8303932,37.5902041 30.7121891,37.4883265 30.5985565,37.3929796 C29.9520258,36.7111837 28.8842707,36.3448163 27.2261483,36.427102 C23.2731687,36.5498776 16.0385565,37.3342041 7.61276054,32.9195102 L7.61276054,8.99004082 C7.61276054,4.65502041 8.71708707,3.29534694 12.6850871,3.29534694 L52.2305565,3.29534694 C55.9902299,3.29534694 57.3172503,4.91102041 57.3172503,8.99004082 L57.3172503,32.7196735 C48.7262299,37.3629388 41.3309646,36.5531429 37.3198626,36.427102 Z"/> <path fill="#000" fill-rule="nonzero" d="M41.3337143,18.9387755 C37.0940408,18.9387755 33.6530612,22.1537959 33.6530612,26.1217959 C33.6530612,30.0897959 37.0940408,33.3048163 41.3337143,33.3048163 C45.5727347,33.3048163 49.0124082,30.0897959 49.0124082,26.1217959 C49.0124082,22.1537959 45.5727347,18.9387755 41.3337143,18.9387755 Z"/> <ellipse cx="23.698" cy="26.122" fill="#000" fill-rule="nonzero" rx="7.678" ry="7.183"/> </g> </svg> <span class="screen-reader-text">Slideshare</span> </a> </li> <li data-service="linkedin"> <a href="https://www.linkedin.com/company/control-engineering-magazine/"> <svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 64 64"> <path d="M0.507092109,20.8266667 L13.8404254,20.8266667 L13.8404254,63.4933333 L0.507092109,63.4933333 L0.507092109,20.8266667 Z M7.57375878,1.18423789e-15 C10.6441294,0.000171308388 13.410568,1.85413069 14.5779338,4.69392525 C15.7452995,7.53371981 15.082559,10.7973256 12.899982,12.9568472 C10.717405,15.1163689 7.44694549,15.7444152 4.6197075,14.546959 C1.79246952,13.3495028 -0.032008046,10.5635327 0.000425442021,7.49333333 C0.0442802881,3.34197226 3.42216607,-0.000231634136 7.57375878,0 Z M21.3333333,19.8666667 L34.6666667,19.8666667 L34.6666667,25.2 L35.4666667,25.2 C38.3528439,21.1358673 43.0154542,18.7053576 48,18.6666667 C61.3333333,18.6666667 64,27.6266667 64,38.96 L64,62.5333333 L50.6666667,62.5333333 L50.6666667,41.5733333 C50.6666667,36.6933333 49.8933333,30.4266667 43.2,30.4266667 C36.5066667,30.4266667 34.6666667,35.7333333 34.6666667,41.2 L34.6666667,62.5333333 L21.3333333,62.5333333 L21.3333333,19.8666667 Z"/> </svg> <span class="screen-reader-text">LinkedIn</span> </a> </li> </ul> </nav> <nav class="siteFooter__menu"> <ul id="menu-footer-navigation" class="menu"><li id="menu-item-38179" class="menu-item menu-item-type-post_type menu-item-object-page menu-item-38179"><a href="https://www.controleng.com/magazine/advisory-board/">Advisory Board</a></li> <li id="menu-item-40503" class="menu-item menu-item-type-custom menu-item-object-custom menu-item-40503"><a href="https://www.cfemedia.com/contact/">Contact</a></li> <li id="menu-item-38180" class="menu-item menu-item-type-post_type menu-item-object-page menu-item-38180"><a href="https://www.controleng.com/connect/how-to-contribute/">Contribute</a></li> <li id="menu-item-38181" class="menu-item menu-item-type-post_type menu-item-object-page menu-item-38181"><a href="https://www.controleng.com/about-us/terms-of-use/">Terms of Use</a></li> <li id="menu-item-38182" class="menu-item menu-item-type-post_type menu-item-object-page menu-item-38182"><a href="https://www.controleng.com/about-us/privacy-policy/">Privacy Policy</a></li> <li id="menu-item-56938" class="menu-item menu-item-type-custom menu-item-object-custom menu-item-56938"><a href="https://csemag.dragonforms.com/do_not_sell&DNS=CE">Do Not Sell</a></li> </ul> </nav> <ul class="networkLogos"> <li class="networkLogos__logo networkLogos__logo--active"><a href="https://www.controleng.com" target="_blank"><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 164 50"> <path fill="#0872B9" d="M39.1 19.9C37 24.7 31.9 27.7 26.8 27.7 19.1 27.7 12.9 21.4 12.9 14.1 12.9 6.9 19 .7 26.7.7 31.1.7 36.7 2.9 39.3 8.6L33.7 8.6C31.8 6.5 29.5 5.2 26.6 5.2 22.3 5.2 17.9 9 17.9 14.2 17.9 19.1 22 23.3 26.8 23.3 30.4 23.3 32.3 21.3 33.5 20L39.1 20 39.1 19.9zM49.6 6.4C55.6 6.4 60.6 11 60.6 17.1 60.6 22.9 55.6 27.6 49.6 27.6 43.5 27.6 38.6 22.9 38.6 17.1 38.6 11 43.6 6.4 49.6 6.4zM49.6 23.7C53.6 23.7 56.7 20.6 56.7 17 56.7 13.3 53.5 10.3 49.6 10.3 45.7 10.3 42.5 13.3 42.5 17 42.5 20.6 45.6 23.7 49.6 23.7zM79.5 6.8L87.4 6.9 87.4 10.4 83.5 10.4 83.5 27.2 79.5 27.2 79.5 6.8zM78.4 6.8L74.5 6.8 70.5 6.8 70.5 10.3 74.5 10.3 74.5 21.6 74.4 21.6 65.7 6.8 61.3 6.8 61.3 27.2 65.2 27.2 65.2 12.4 65.3 12.4 74.1 27.2 78.5 27.2 78.4 6.8zM88.2 6.8L94.7 6.8C97.1 6.8 98.6 7.2 99.8 8.2 101 9.1 102.3 10.8 102.3 13.1 102.3 14.4 101.8 16.6 100.3 18 99 19.2 97.8 19.4 96.8 19.7L102.5 27.2 97.8 27.2 92.2 19.4 92.1 19.4 92.1 27.2 88.2 27.2 88.2 6.8zM92.1 16.6L94.6 16.6C97.8 16.6 98.4 14.5 98.4 13.5 98.4 12.4 97.7 10.4 94.6 10.4L92.1 10.4 92.1 16.6zM113.3 6.4C119.3 6.4 124.3 11 124.3 17.1 124.3 22.9 119.3 27.6 113.3 27.6 107.2 27.6 102.3 22.9 102.3 17.1 102.3 11 107.3 6.4 113.3 6.4zM113.3 23.7C117.3 23.7 120.4 20.6 120.4 17 120.4 13.3 117.2 10.3 113.3 10.3 109.3 10.3 106.2 13.3 106.2 17 106.2 20.6 109.3 23.7 113.3 23.7zM125.2 6.8L129.1 6.8 129.1 23.6 135.5 23.6 135.5 27.1 125.1 27.1 125.1 6.8 125.2 6.8zM.6 22.9L15.1 22.9 15.1 27.4 5.6 27.4 5.6 33.8 14.7 33.8 14.7 38.3 5.6 38.3 5.6 44.4 15.1 44.4 15.1 48.9.6 48.9.6 22.9zM15.7 28.5L20.2 28.5 28.9 43.3 29 43.3 29 28.5 32.9 28.5 32.9 48.9 28.5 48.9 19.7 34 19.6 34 19.6 48.8 15.7 48.8 15.7 28.5zM42.2 38.5L56 38.5 56 38.9C56 44.7 50.7 49.2 44.8 49.2 38.8 49.2 33.4 44.7 33.4 38.6 33.4 32.6 38.7 28 44.6 28 49.9 28 53.8 31.5 54.8 34.4L50.1 34.4C49.2 33.1 47.2 31.7 44.5 31.7 39.7 31.7 37.3 35.5 37.3 38.6 37.3 41.6 39.7 45.5 44.7 45.5 47.3 45.5 49.7 44.3 50.9 41.9L42.1 41.9 42.1 38.5 42.2 38.5zM56.4 28.5L60.3 28.5 60.3 48.9 56.4 48.9 56.4 28.5zM61.3 28.5L65.8 28.5 74.5 43.3 74.6 43.3 74.6 28.5 78.5 28.5 78.5 48.9 74 48.9 65.2 34 65.1 34 65.1 48.8 61.2 48.8 61.2 28.5 61.3 28.5zM79.5 28.5L90.9 28.5 90.9 32 83.5 32 83.5 37 90.6 37 90.6 40.5 83.5 40.5 83.5 45.3 90.9 45.3 90.9 48.8 79.5 48.8 79.5 28.5zM91.8 28.5L103.2 28.5 103.2 32 95.8 32 95.8 37 102.9 37 102.9 40.5 95.8 40.5 95.8 45.3 103.2 45.3 103.2 48.8 91.8 48.8 91.8 28.5zM104 28.5L110.5 28.5C112.9 28.5 114.4 28.9 115.6 29.9 116.8 30.8 118.1 32.5 118.1 34.8 118.1 36.1 117.6 38.3 116.1 39.7 114.8 40.9 113.6 41.1 112.6 41.4L118.3 48.9 113.6 48.9 108 41.1 107.9 41.1 107.9 48.9 104 48.9 104 28.5zM107.9 38.2L110.4 38.2C113.6 38.2 114.2 36.1 114.2 35.1 114.2 34 113.5 32 110.4 32L107.9 32 107.9 38.2zM118.3 28.5L122.2 28.5 122.2 48.9 118.3 48.9 118.3 28.5zM123.2 28.5L127.7 28.5 136.4 43.3 136.5 43.3 136.5 28.5 140.4 28.5 140.4 48.9 136 48.9 127.1 34 127 34 127 48.8 123.1 48.8 123.1 28.5 123.2 28.5zM149.7 38.5L163.5 38.5 163.5 38.9C163.5 44.7 158.2 49.2 152.3 49.2 146.3 49.2 140.9 44.7 140.9 38.6 140.9 32.6 146.2 28 152.1 28 157.4 28 161.3 31.5 162.3 34.4L157.6 34.4C156.7 33.1 154.7 31.7 152 31.7 147.2 31.7 144.8 35.5 144.8 38.6 144.8 41.6 147.2 45.5 152.2 45.5 154.8 45.5 157.2 44.3 158.4 41.9L149.6 41.9 149.6 38.5 149.7 38.5zM160.4 48.1C160.4 47.4 161 46.8 161.7 46.8 162.4 46.8 163 47.3 163 48.1 163 48.8 162.4 49.4 161.7 49.4 161 49.3 160.4 48.8 160.4 48.1zM161.7 49.1C162.3 49.1 162.7 48.7 162.7 48.1 162.7 47.5 162.3 47.1 161.7 47.1 161.1 47.1 160.7 47.5 160.7 48.1 160.7 48.7 161.1 49.1 161.7 49.1zM161.5 48.8L161.3 48.8 161.3 47.4 161.9 47.4C162.2 47.4 162.4 47.5 162.4 47.8 162.4 48.1 162.2 48.2 162 48.2L162.4 48.8 162.2 48.8 161.8 48.2 161.5 48.2 161.5 48.8zM161.7 48C161.9 48 162.1 48 162.1 47.8 162.1 47.6 161.9 47.6 161.8 47.6L161.5 47.6 161.5 48 161.7 48z" /> </svg> </a></li><li class="networkLogos__logo "><a href="https://www.plantengineering.com" target="_blank"><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 168 64"> <g fill="#20407C"> <path d="M6.4,0.7 L15.1,0.7 C20.1,0.7 23,4.9 21.5,13.7 C20.2,20.9 16.7,25.4 12.4,25.4 L8.4,25.4 L6.6,36 L0.2,36 L6.4,0.7 Z M9.8,18 L10.6,18 C13,17.9 14.5,17.3 15.1,13.2 C15.8,8.7 14,8.4 12.2,8.4 L11.5,8.4 L9.8,18 Z" /> <polygon points="25.5 .5 31 .5 28 17.6 32.6 17.6 31.2 25.7 21.1 25.7" /> <path d="M37.3,25.7 L31.4,25.7 L41.1,0.5 L47.2,0.5 L48.2,25.7 L42.3,25.7 L42.3,22.6 L38.1,22.6 L37.3,25.7 Z M42.5,16.6 L42.6,12.1 C42.6,11 42.7,9.9 42.8,8.9 L42.6,8.9 L40.3,16.6 L42.5,16.6 Z" /> <path d="M53.7,0.5 L59,0.5 L61.5,14.5 L61.7,14.5 C61.8,12.4 62,10.2 62.4,8.1 L63.7,0.5 L69,0.5 L64.6,25.7 L59.3,25.7 L56.7,12.4 L56.5,12.4 C56.4,14.1 56.3,15.8 56,17.5 L54.6,25.7 L49.3,25.7 L53.7,0.5 Z" /> <polygon points="70.3 .5 81.9 .5 80.5 8.6 77.5 8.6 74.5 25.8 69 25.8 72 8.6 68.9 8.6" /> <polygon points="10.5 28.1 23.7 28.1 22.3 36.5 15.5 36.5 14.6 42.1 20.7 42.1 19.5 49 13.4 49 12.4 55 19 55 17.6 63.5 4.3 63.5" /> <path d="M25.4 28.3L30.7 28.3 33.2 42.3 33.4 42.3C33.5 40.2 33.7 38 34.1 35.9L35.4 28.3 40.7 28.3 36.3 53.5 31 53.5 28.4 40.2 28.2 40.2C28.1 41.9 28 43.6 27.7 45.3L26.3 53.5 21 53.5 25.4 28.3zM57.1 38.7C56.3 42.8 55.7 46.3 53.4 49.5 51.3 52.4 48.5 54 46.2 54 41.6 54 38.6 49.2 40 41.1 41.4 32.9 45.9 27.9 50.7 27.9 53.3 27.9 56.6 30.1 57 34.4L51.3 37.5C51.1 36.2 50.4 35.6 49.5 35.6 47.5 35.6 45.9 38.4 45.4 41.5 44.9 44.3 45.5 46.9 47.3 46.9 48.2 46.9 49.4 46.2 49.9 44.7L47.4 44.7 48.4 38.7 57.1 38.7z" /> <polygon points="60.6 28.3 66.1 28.3 61.7 53.5 56.2 53.5" /> <path d="M67.8,28.3 L73.1,28.3 L75.6,42.3 L75.8,42.3 C75.9,40.2 76.1,38 76.5,35.9 L77.8,28.3 L83.1,28.3 L78.7,53.5 L73.4,53.5 L70.8,40.2 L70.6,40.2 C70.5,41.9 70.4,43.6 70.1,45.3 L68.7,53.5 L63.4,53.5 L67.8,28.3 Z" /> <polygon points="84.5 28.3 94.7 28.3 93.5 35.2 88.8 35.2 88.4 37.6 92.7 37.6 91.6 44.2 87.3 44.2 86.9 46.7 91.7 46.7 90.5 53.6 80.1 53.6" /> <polygon points="96.3 28.3 106.5 28.3 105.3 35.2 100.6 35.2 100.2 37.6 104.5 37.6 103.4 44.2 99.1 44.2 98.7 46.7 103.5 46.7 102.3 53.6 91.9 53.6" /> <path d="M108.1,28.3 L114.8,28.3 C118.2,28.3 120.7,30.7 119.6,37.1 C118.9,40.9 117.8,42.5 115.5,43.7 L115.5,43.9 C115.7,44.3 116,44.7 116.2,45.4 L118.1,53.6 L111.7,53.6 L110.7,45.5 L110.6,45.5 L109.2,53.6 L103.8,53.6 L108.1,28.3 Z M111.6,39.5 L112,39.5 C112.9,39.5 113.9,39.3 114.2,37.4 C114.5,35.5 113.8,35.2 112.8,35.2 L112.4,35.2 L111.6,39.5 Z" /> <polygon points="123.5 28.3 129 28.3 124.6 53.5 119.1 53.5" /> <path d="M130.9 28.3L136.2 28.3 138.7 42.3 138.9 42.3C139 40.2 139.2 38 139.6 35.9L140.9 28.3 146.2 28.3 141.8 53.5 136.5 53.5 133.9 40.2 133.7 40.2C133.6 41.9 133.5 43.6 133.2 45.3L131.8 53.5 126.5 53.5 130.9 28.3zM162.6 38.7C161.8 42.8 161.2 46.3 158.9 49.5 156.8 52.4 154 54 151.7 54 147.1 54 144.1 49.2 145.5 41.1 146.9 32.9 151.4 27.9 156.2 27.9 158.8 27.9 162.1 30.1 162.5 34.4L156.8 37.5C156.6 36.2 155.9 35.6 155 35.6 153 35.6 151.4 38.4 150.9 41.5 150.4 44.3 151 46.9 152.8 46.9 153.7 46.9 154.9 46.2 155.4 44.7L153 44.7 154 38.7 162.6 38.7z" /> <path d="M165.4,27 C166.7,27 167.8,28.1 167.8,29.4 C167.8,30.7 166.7,31.8 165.4,31.8 C164.1,31.8 163,30.7 163,29.4 C163,28 164.1,27 165.4,27 Z M165.4,31.5 C166.6,31.5 167.5,30.6 167.5,29.4 C167.5,28.2 166.5,27.3 165.4,27.3 C164.2,27.3 163.3,28.2 163.3,29.4 C163.3,30.5 164.2,31.5 165.4,31.5 Z M164,30.6 C164.4,30.6 164.5,30.5 164.5,30.3 L164.5,28.4 C164.5,28.2 164.5,28.1 164,28.1 L164,27.9 L165.4,27.9 C165.8,27.9 166.5,28.1 166.5,28.6 C166.5,29 165.9,29.3 165.6,29.3 C165.9,29.4 166.2,29.7 166.3,30.1 C166.3,30.4 166.4,30.5 166.5,30.5 C166.6,30.5 166.7,30.4 166.8,30 L167,30 C167,30.4 166.9,30.7 166.4,30.7 C166,30.7 165.8,30.5 165.8,30 C165.8,29.5 165.6,29.3 165.2,29.3 L165,29.3 L165,30.2 C165,30.4 165,30.5 165.5,30.5 L165.5,30.7 L164,30.7 L164,30.6 Z M165,29.2 L165.2,29.2 C165.7,29.2 166,29 166,28.6 C166,28.3 165.8,28.1 165.3,28.1 C165.1,28.1 165,28.2 165,28.3 L165,29.2 Z" /> </g> </svg> </a></li><li class="networkLogos__logo "><a href="https://www.csemag.com" target="_blank"><svg xmlns="http://www.w3.org/2000/svg" viewBox="0 0 210 54"> <g fill="#961417"> <path d="M207 10.1C208.5 10.1 209.7 11.3 209.7 12.8 209.7 14.3 208.5 15.5 207 15.5 205.5 15.5 204.3 14.3 204.3 12.8 204.2 11.3 205.5 10.1 207 10.1zM207 15.3C208.3 15.3 209.4 14.2 209.4 12.9 209.4 11.6 208.3 10.5 207 10.5 205.7 10.5 204.6 11.6 204.6 12.9 204.6 14.2 205.6 15.3 207 15.3zM205.4 14.2C205.9 14.2 205.9 14.1 205.9 13.8L205.9 11.7C205.9 11.4 205.9 11.4 205.4 11.4L205.4 11.2 207 11.2C207.5 11.2 208.3 11.4 208.3 12 208.3 12.5 207.6 12.8 207.2 12.8 207.6 12.9 207.9 13.3 208 13.7 208.1 14.1 208.1 14.2 208.2 14.2 208.4 14.2 208.5 14.1 208.5 13.6L208.7 13.6C208.7 14 208.5 14.4 208.1 14.4 207.7 14.4 207.5 14.2 207.5 13.6 207.5 13 207.2 12.8 206.8 12.8L206.6 12.8 206.6 13.8C206.6 14.1 206.6 14.1 207.1 14.2L207.1 14.4 205.5 14.4 205.5 14.2 205.4 14.2zM206.5 12.7L206.8 12.7C207.4 12.7 207.7 12.5 207.7 12 207.7 11.6 207.5 11.4 206.9 11.4 206.6 11.4 206.5 11.5 206.5 11.7L206.5 12.7zM144.9 21.6C144.8 20.3 143.5 18 140.8 17.9 137.5 17.8 136.3 20.2 135.9 21.6L144.9 21.6zM135.7 28.8C136.1 33.6 139 34.4 140.7 34.4 141.7 34.4 142.7 34.1 143.4 33.7 143.9 33.4 144.3 33 144.9 32.3L154.3 32.3C153.8 33.8 152.8 36.5 150.1 38.8 146.7 41.6 142.3 41.9 140.6 41.9 138 41.9 135.4 41.4 132.8 39.9 129 37.7 126 33.1 126 26.2 126 22.3 127.1 19.5 128.1 17.6 131.4 11.4 137.2 10.6 140.2 10.6 144.2 10.6 148.7 11.6 151.8 16.3 154.6 20.5 154.7 25.6 154.8 28.9L135.7 28.8z" /> <path d="M172.7 21.6C172.5 20.3 171.3 18 168.6 17.9 165.3 17.8 164.1 20.2 163.7 21.6L172.7 21.6zM163.4 28.8C163.8 33.6 166.7 34.4 168.4 34.4 169.4 34.4 170.4 34.1 171.1 33.7 171.6 33.4 172 33 172.6 32.3L182 32.3C181.5 33.8 180.6 36.5 177.8 38.8 174.4 41.6 170 41.9 168.2 41.9 165.6 41.9 163 41.4 160.4 39.9 156.6 37.7 153.7 33.1 153.7 26.2 153.7 22.3 154.8 19.5 155.8 17.6 159.1 11.4 164.9 10.6 167.9 10.6 171.9 10.6 176.4 11.6 179.5 16.3 182.3 20.5 182.4 25.6 182.5 28.9L163.4 28.8zM19.2 21.6C19 20.3 17.8 18 15.1 17.9 11.8 17.8 10.6 20.2 10.2 21.6L19.2 21.6zM9.9 28.8C10.3 33.6 13.2 34.4 14.9 34.4 15.9 34.4 16.9 34.1 17.6 33.7 18.1 33.4 18.5 33 19.1 32.3L28.5 32.3C28 33.8 27 36.5 24.3 38.8 20.9 41.6 16.5 41.9 14.8 41.9 12.2 41.9 9.6 41.4 7 39.9 3.2 37.7.3 33.1.3 26.2.3 22.3 1.4 19.5 2.4 17.6 5.7 11.4 11.5 10.6 14.5 10.6 18.5 10.6 23 11.6 26.1 16.3 28.9 20.5 29 25.6 29.1 28.9L9.9 28.8z" /> <path d="M39.4,15.2 C41.3,12.5 43.6,10.6 47.7,10.6 C50.3,10.6 52.4,11.4 54,12.8 C57.3,15.6 57.1,19.7 57.1,25.5 L57.1,41 L47.1,41 L47.1,27.5 C47.1,25.6 47.1,24.3 47,23.5 C46.9,20.5 45.5,19.6 43.9,19.6 C42.8,19.6 41.7,20.1 41.1,20.9 C39.7,22.6 39.9,25.2 39.9,27.9 L39.9,41 L29.7,41 L29.7,11.3 L39.4,11.3 L39.4,15.2" /> <path d="M66.9,25.1 C66.9,28.3 69,30.7 71.9,30.7 C74.4,30.7 76.8,28.8 76.8,25 C76.8,20.9 73.9,19.4 71.6,19.5 C68.3,19.6 66.9,22.5 66.9,25.1 Z M68.9,41.7 C69,44.9 71,45.6 73.1,45.6 C74.3,45.6 75.2,45.1 76.3,43.7 C77.4,42.2 77.4,41.9 77.3,37.3 C76.5,38 75.8,38.5 74.4,39.2 C72.6,39.9 70.8,39.8 69,39.8 C63.4,39.8 57.8,34.7 57.8,25.4 C57.8,17.6 62.1,10.9 69.8,10.9 C74.7,10.9 76.1,13.2 76.8,14.7 L76.8,11.5 L86.7,11.5 L86.7,38.6 C86.7,41.8 86.5,46.2 83.6,49.2 C82.3,50.6 79.2,53.5 72,53.5 C68.4,53.5 64.8,52.7 62,49.7 C59.2,46.8 59.5,43.5 59.3,41.6 L68.9,41.6 L68.9,41.7 Z" /> <polyline points="88.1 11.5 97.9 11.5 97.9 41 88.1 41 88.1 11.5" /> <path d="M108.9 15.3C110.6 13 113 11 117.2 11 119.9 11 121.8 11.6 123.5 13.1 126.6 15.8 126.8 19.7 126.8 25.6L126.8 41.2 116.6 41.2 116.6 27.6C116.6 25.6 116.6 24.3 116.6 23.6 116.4 20.8 114.9 19.6 113.2 19.6 112.1 19.6 111.3 20 110.5 21 109.3 22.6 109.4 25.3 109.4 27.9L109.4 41.1 99.3 41.1 99.3 11.5 109 11.5 109 15.3M191.3 16.1C192.3 13.9 194 12.4 195.8 11.4 197.8 10.3 200.6 9.8 201.7 10.5L201.7 21.2C200.5 20.6 198.4 20.3 197.6 20.3 195.1 20.3 192 22.2 191.7 27.7L191.7 41 181.6 41 181.6 11.5 191.3 11.5 191.3 16.1M17.1 4.6C16.9 5.4 16.7 6.1 16 6.6 15.4 7.1 14.4 7.3 12.9 7.3 11.4 7.3 8.5 7.2 8.5 3.9 8.5.6 11.3.5 12.9.5 14.4.5 16.8.7 17.1 3.2L14.3 3.2C14.2 2.7 13.9 2.1 13 2.1 12 2.1 11.3 2.6 11.3 3.9 11.3 5.2 11.9 5.7 12.9 5.7 13.7 5.7 14.2 5.4 14.4 4.6L17.1 4.6z" /> <path d="M21.9,5.7 C22.9,5.7 23.6,5.2 23.6,3.9 C23.6,2.6 23,2.1 21.9,2.1 C20.9,2.1 20.2,2.6 20.2,3.9 C20.2,5.2 20.8,5.7 21.9,5.7 Z M21.9,0.5 C23.4,0.5 26.3,0.6 26.3,3.9 C26.3,7.2 23.5,7.3 21.9,7.3 C20.4,7.3 17.5,7.2 17.5,3.9 C17.5,0.6 20.3,0.5 21.9,0.5 Z" /> <polygon points="26.9 .7 29.8 .7 32.4 4.3 32.4 4.3 32.4 .7 34.8 .7 34.8 7.1 32 7.1 29.4 3.5 29.3 3.5 29.3 7.1 26.9 7.1" /> <path d="M37.3 4.4C36.1 4.2 35.6 3.5 35.6 2.6 35.6 1 37.2.5 39.3.5 42.1.5 43.3 1.2 43.4 2.6L40.5 2.6C40.5 2.3 40.3 2.2 40.1 2.1 39.8 2 39.5 2 39.2 2 38.4 2 38.2 2.2 38.2 2.4 38.2 2.6 38.3 2.7 38.5 2.7L41.5 3.1C42.8 3.3 43.6 3.9 43.6 5 43.6 6.6 42.3 7.3 39.5 7.3 37.6 7.3 35.4 7 35.4 5.2L38.4 5.2C38.4 5.4 38.5 5.6 38.7 5.6 38.9 5.7 39.2 5.7 39.6 5.7 40.4 5.7 40.6 5.5 40.6 5.2 40.6 5 40.5 4.8 40.1 4.8L37.3 4.4zM44.2.7L46.7.7 46.7 4.6C46.7 5.4 47.2 5.7 48 5.7 48.8 5.7 49.3 5.4 49.3 4.6L49.3.7 51.8.7 51.8 4.7C51.8 6.7 50.6 7.3 48 7.3 45.4 7.3 44.2 6.7 44.2 4.7L44.2.7z" /> <polygon points="52.7 .7 55.2 .7 55.2 5.4 59.1 5.4 59.1 7.1 52.7 7.1" /> <polygon points="60.5 2.3 58.2 2.3 58.2 .7 65.3 .7 65.3 2.3 63 2.3 63 7.1 60.5 7.1" /> <polygon points="66.5 .7 69 .7 69 7.1 66.5 7.1" /> <polygon points="70.1 .7 72.9 .7 75.5 4.3 75.5 4.3 75.5 .7 77.9 .7 77.9 7.1 75.2 7.1 72.5 3.5 72.5 3.5 72.5 7.1 70.1 7.1" /> <path d="M83.5,3.5 L87.1,3.5 L87.1,7.1 L86,7.1 L85.7,6.5 C85.1,7.1 84.2,7.3 82.8,7.3 C81,7.3 78.6,6.9 78.6,3.9 C78.6,1.1 80.8,0.5 82.8,0.5 C85.6,0.5 87,1.3 87.1,2.9 L84.3,2.9 C84.2,2.6 84,2.4 83.8,2.2 C83.6,2.1 83.3,2 82.9,2 C81.9,2 81.2,2.5 81.2,3.8 C81.2,5 81.8,5.6 83.1,5.6 C83.9,5.6 84.3,5.3 84.5,4.8 L83.5,4.8 L83.5,3.5 Z" /> <polygon points="91 3.8 95.4 3.8 95.4 5.2 91 5.2" /> <path d="M101.1,4.4 C99.9,4.2 99.4,3.5 99.4,2.6 C99.4,1 101,0.5 103.1,0.5 C105.9,0.5 107.1,1.2 107.2,2.6 L104.3,2.6 C104.3,2.3 104.1,2.2 103.9,2.1 C103.7,2 103.4,2 103.1,2 C102.4,2 102.1,2.2 102.1,2.4 C102.1,2.6 102.2,2.7 102.4,2.7 L105.4,3.1 C106.7,3.3 107.5,3.9 107.5,5 C107.5,6.6 106.2,7.3 103.4,7.3 C101.5,7.3 99.4,7 99.3,5.2 L102.3,5.2 C102.3,5.4 102.4,5.6 102.6,5.6 C102.8,5.7 103.1,5.7 103.4,5.7 C104.2,5.7 104.4,5.5 104.4,5.2 C104.4,5 104.3,4.8 103.9,4.8 L101.1,4.4 Z" /> <path d="M110.6,3.6 L112.2,3.6 C112.8,3.6 113.1,3.4 113.1,2.9 C113.1,2.4 112.9,2.2 112.2,2.2 L110.6,2.2 L110.6,3.6 Z M108.1,0.7 L113.3,0.7 C115.1,0.7 115.7,1.5 115.7,2.9 C115.7,4.1 115.1,5.1 113.3,5.1 L110.6,5.1 L110.6,7.1 L108.1,7.1 L108.1,0.7 Z" /> <polygon points="116.4 .7 123.2 .7 123.2 2.3 118.9 2.3 118.9 3.1 122.8 3.1 122.8 4.7 118.9 4.7 118.9 5.5 123.2 5.5 123.2 7.1 116.4 7.1" /> <path d="M132,4.6 C131.8,5.4 131.5,6.1 130.9,6.6 C130.3,7.1 129.3,7.3 127.8,7.3 C126.3,7.3 123.4,7.2 123.4,3.9 C123.4,0.6 126.2,0.5 127.8,0.5 C129.3,0.5 131.7,0.7 132,3.2 L129.2,3.2 C129.1,2.7 128.8,2.1 127.8,2.1 C126.8,2.1 126.1,2.6 126.1,3.9 C126.1,5.2 126.7,5.7 127.7,5.7 C128.5,5.7 129,5.4 129.2,4.6 L132,4.6 Z" /> <polygon points="133.4 .7 136 .7 136 7.1 133.4 7.1" /> <polygon points="137.1 .7 143.5 .7 143.5 2.3 139.6 2.3 139.6 3.3 143.2 3.3 143.2 4.8 139.6 4.8 139.6 7.1 137.1 7.1" /> <polygon points="146.5 5.3 143.7 .7 146.6 .7 147.8 3.2 149 .7 151.9 .7 149 5.3 149 7.1 146.5 7.1" /> <polygon points="152.7 .7 155.2 .7 155.2 7.1 152.7 7.1" /> <polygon points="156.2 .7 159.1 .7 161.7 4.3 161.7 4.3 161.7 .7 164.1 .7 164.1 7.1 161.4 7.1 158.7 3.5 158.7 3.5 158.7 7.1 156.2 7.1" /> <path d="M169.8,3.5 L173.4,3.5 L173.4,7.1 L172.3,7.1 L172,6.5 C171.3,7.1 170.5,7.3 169.1,7.3 C167.3,7.3 164.9,6.9 164.9,3.9 C164.9,1.1 167.1,0.5 169.1,0.5 C171.9,0.5 173.2,1.3 173.4,2.9 L170.6,2.9 C170.5,2.6 170.3,2.4 170.1,2.2 C169.9,2.1 169.6,2 169.3,2 C168.3,2 167.6,2.5 167.6,3.8 C167.6,5 168.2,5.6 169.5,5.6 C170.3,5.6 170.7,5.3 170.9,4.8 L169.9,4.8 L169.9,3.5 L169.8,3.5 Z" /> </g> </svg> </a></li><li class="networkLogos__logo"><a href="https://www.industrialcybersecuritypulse.com" target="_blank"> <!-- Generator: Adobe Illustrator 25.2.1, SVG Export Plug-In . SVG Version: 6.00 Build 0) --> <svg id="Layer_1" xmlns="http://www.w3.org/2000/svg" viewBox="0 0 282 70"> .st0{fill:#0583A5;} .st1{fill:#515150;} <g> <g> <path fill="#0583A5" d="M25.3,27.3l-0.6,2.4h-5.5c-0.1,0-0.2,0-0.3,0.1c-0.1,0-0.1,0.1-0.2,0.1c-0.1,0-0.1,0.1-0.1,0.1 c-0.1,0.1-0.2,0.2-0.2,0.2c0,0-0.1,0.1-0.1,0.1c0,0,0,0.1,0,0.1l-2.2,8.2c0,0.1,0,0.2,0,0.2c0,0,0,0.1,0,0.1c0,0,0.1,0.1,0.1,0.1 c0,0,0.1,0.1,0.1,0.1c0,0,0.1,0.1,0.1,0.1c0,0,0.1,0,0.1,0.1c0,0,0.1,0,0.1,0h5.6l-0.6,2.4h-8.5c-0.1,0-0.2,0-0.3,0 c-0.1,0-0.2,0-0.3-0.1c-0.1,0-0.2,0-0.3-0.1c-0.1,0-0.2-0.1-0.3-0.1c-0.1,0-0.2-0.1-0.2-0.1c-0.1-0.1-0.1-0.1-0.2-0.2 c-0.1-0.1-0.1-0.1-0.2-0.2c-0.1-0.1-0.1-0.2-0.1-0.3c0-0.1-0.1-0.1-0.1-0.2c0-0.1-0.1-0.2-0.1-0.3c0-0.1,0-0.2-0.1-0.3 c0-0.1,0-0.2,0-0.3c0-0.1,0-0.2,0-0.3s0-0.2,0-0.3c0-0.1,0-0.2,0.1-0.3c0-0.1,0.1-0.2,0.1-0.4l2-7.4c0-0.1,0.1-0.2,0.1-0.4 c0-0.1,0.1-0.2,0.1-0.3c0-0.1,0.1-0.2,0.2-0.3c0.1-0.1,0.1-0.2,0.2-0.3c0.1-0.1,0.1-0.2,0.2-0.3c0.1-0.1,0.2-0.2,0.2-0.3 c0.1-0.1,0.1-0.2,0.2-0.3c0.1-0.1,0.2-0.2,0.3-0.3c0.1-0.1,0.2-0.1,0.2-0.2c0.1-0.1,0.2-0.1,0.2-0.2c0.1-0.1,0.2-0.1,0.3-0.2 c0.1-0.1,0.2-0.1,0.3-0.1c0.1-0.1,0.2-0.1,0.3-0.2c0.1,0,0.2-0.1,0.3-0.1c0.1,0,0.2-0.1,0.3-0.1c0.1,0,0.2,0,0.3,0H25.3z" /> <path fill="#0583A5" d="M28.8,36.2l-2.9-8.8h5.9l2,5.9l4.9-5.9h2.6l-7.6,9.1l-1.4,5.4h-5L28.8,36.2z" /> <path fill="#0583A5" d="M54,27.4c0.1,0,0.2,0,0.3,0c0.1,0,0.2,0,0.3,0c0.1,0,0.2,0,0.3,0.1c0.1,0,0.2,0,0.3,0.1 c0.1,0,0.2,0.1,0.3,0.1c0.1,0,0.2,0.1,0.2,0.1c0.1,0,0.1,0.1,0.2,0.2c0.1,0.1,0.1,0.1,0.2,0.2c0.1,0.1,0.1,0.1,0.2,0.2 c0,0.1,0.1,0.1,0.1,0.2c0,0.1,0.1,0.1,0.1,0.2c0,0.1,0,0.2,0.1,0.2c0,0.1,0,0.2,0,0.2c0,0.1,0,0.2,0,0.2c0,0.1,0,0.2,0,0.3 c0,0.1,0,0.2,0,0.3l-0.7,2.6c0,0.1,0,0.2-0.1,0.3c0,0.1-0.1,0.2-0.1,0.2c0,0.1-0.1,0.1-0.2,0.2c-0.1,0.1-0.1,0.1-0.2,0.2 c-0.1,0.1-0.1,0.1-0.2,0.2c-0.1,0-0.1,0.1-0.2,0.1c-0.1,0-0.1,0.1-0.2,0.1c-0.1,0-0.2,0.1-0.2,0.1c0,0-0.1,0-0.2,0.1 C54.1,34,54,34,54,34c-0.1,0-0.1,0-0.2,0.1c-0.1,0-0.1,0-0.2,0c-0.1,0-0.2,0-0.3,0.1c-0.1,0-0.2,0-0.3,0c-0.1,0-0.2,0-0.3,0 c-0.1,0-0.2,0-0.3,0c0.1,0,0.2,0,0.3,0.1c0.1,0,0.2,0,0.3,0.1c0.1,0,0.2,0.1,0.3,0.1c0.1,0,0.2,0,0.3,0.1c0.1,0,0.2,0.1,0.4,0.1 c0.1,0.1,0.2,0.1,0.3,0.2c0,0,0.1,0.1,0.1,0.1c0,0,0.1,0.1,0.1,0.1c0,0,0.1,0.1,0.1,0.1c0,0,0.1,0.1,0.1,0.1 c0,0.1,0.1,0.1,0.1,0.2c0,0.1,0.1,0.1,0.1,0.2c0,0.1,0,0.2,0,0.3c0,0.1,0,0.2,0,0.3l-0.9,3.3c0,0.1-0.1,0.2-0.1,0.4 c0,0.1-0.1,0.2-0.1,0.3c-0.1,0.1-0.1,0.2-0.2,0.3c-0.1,0.1-0.1,0.2-0.2,0.3c-0.1,0.1-0.1,0.1-0.2,0.2c-0.1,0.1-0.2,0.1-0.2,0.2 c-0.1,0.1-0.2,0.1-0.2,0.2c-0.1,0.1-0.2,0.1-0.2,0.2c-0.1,0-0.2,0.1-0.2,0.1c-0.1,0-0.2,0.1-0.2,0.1c-0.1,0-0.2,0.1-0.3,0.1 c-0.1,0-0.2,0.1-0.3,0.1c-0.1,0-0.2,0.1-0.3,0.1c-0.1,0-0.2,0-0.3,0c-0.1,0-0.2,0-0.3,0c-0.1,0-0.2,0-0.3,0H39.4l3.8-14.4H54z M46.1,35.5l-1,3.9h3.3c0,0,0.1,0,0.1,0c0,0,0.1,0,0.1,0c0,0,0.1,0,0.1-0.1c0,0,0.1-0.1,0.1-0.1c0,0,0.1-0.1,0.1-0.1 c0,0,0.1-0.1,0.1-0.1c0,0,0-0.1,0.1-0.1c0,0,0-0.1,0.1-0.1l0.7-2.6c0,0,0-0.1,0-0.1c0,0,0-0.1,0-0.1c0,0,0-0.1-0.1-0.1 c0,0,0-0.1-0.1-0.1c0,0-0.1,0-0.1-0.1c0,0-0.1,0-0.1-0.1c0,0,0,0-0.1,0c0,0-0.1,0-0.1,0H46.1z M47.6,29.7l-0.9,3.4h3.2 c0,0,0.1,0,0.1,0c0,0,0.1,0,0.1-0.1c0.1,0,0.1,0,0.1-0.1c0,0,0.1-0.1,0.1-0.1c0,0,0.1-0.1,0.1-0.1c0,0,0.1-0.1,0.1-0.1 c0.1-0.1,0.1-0.2,0.1-0.2l0.6-2.2c0,0,0-0.1,0-0.1c0,0,0-0.1,0-0.1c0,0,0-0.1,0-0.1c0,0,0-0.1-0.1-0.1c0,0-0.1,0-0.1-0.1 c0,0-0.1,0-0.1-0.1c0,0-0.1,0-0.1,0c0,0-0.1,0-0.1,0H47.6z" /> <path fill="#0583A5" d="M58.8,27.4h11.1l-0.6,2.3h-6l-0.9,3.5h5.9l-0.6,2.3h-5.9l-1,3.9h6.2l-0.6,2.3H55L58.8,27.4z" /> <path fill="#0583A5" d="M71.7,27.4h10.8c0.3,0,0.5,0,0.7,0.1c0.2,0,0.4,0.1,0.6,0.1c0.2,0.1,0.3,0.2,0.5,0.3c0.1,0.1,0.3,0.2,0.3,0.4 c0,0.1,0.1,0.1,0.1,0.2c0,0.1,0.1,0.2,0.1,0.3c0,0.1,0,0.2,0,0.3c0,0.1,0,0.2,0,0.3c0,0.2,0,0.3-0.1,0.5c0,0.2-0.1,0.4-0.1,0.6 l-0.8,3c0,0.1-0.1,0.1-0.1,0.2c0,0.1,0,0.1-0.1,0.2c0,0.1,0,0.1-0.1,0.2c0,0.1-0.1,0.2-0.1,0.2c0,0.1-0.1,0.1-0.1,0.2 c0,0.1-0.1,0.1-0.1,0.2c0,0.1-0.1,0.1-0.2,0.2c-0.1,0.1-0.1,0.1-0.2,0.2c0,0-0.1,0.1-0.1,0.1c-0.1,0-0.1,0.1-0.2,0.1 c-0.1,0-0.1,0.1-0.2,0.1c-0.1,0-0.1,0.1-0.2,0.1c-0.1,0-0.1,0.1-0.2,0.1c-0.1,0-0.2,0-0.2,0c-0.1,0-0.2,0-0.3,0 c-0.1,0-0.2,0-0.3,0l1.2,6.2h-5.6l-0.7-6.2h-1.6l-1.7,6.2h-5L71.7,27.4z M76.2,29.7l-0.9,3.4h3.2c0.1,0,0.1,0,0.2,0 c0,0,0.1,0,0.1,0c0,0,0.1,0,0.1-0.1c0,0,0.1-0.1,0.1-0.1c0,0,0,0,0.1-0.1c0,0,0-0.1,0.1-0.1c0,0,0-0.1,0.1-0.1c0,0,0-0.1,0.1-0.2 l0.6-2.2c0,0,0-0.1,0-0.1c0,0,0-0.1,0-0.1c0,0,0-0.1,0-0.1c0,0,0-0.1-0.1-0.1c0,0,0,0-0.1-0.1c0,0-0.1,0-0.1,0c0,0-0.1,0-0.1,0 c0,0-0.1,0-0.1,0H76.2z" /> <path fill="#0583A5" d="M100.2,27.4l-0.6,2.4h-6.7c0,0-0.1,0-0.1,0c0,0-0.1,0-0.1,0c0,0-0.1,0-0.1,0.1c0,0-0.1,0-0.1,0.1 c0,0-0.1,0.1-0.1,0.1c0,0-0.1,0-0.1,0.1c0,0-0.1,0.1-0.1,0.1c0,0,0,0.1,0,0.1l-0.3,1.1c0,0,0,0.1,0,0.1c0,0,0,0,0,0.1 c0,0,0,0.1,0,0.1c0,0,0,0.1,0,0.1c0,0,0,0.1,0.1,0.1c0,0,0.1,0.1,0.1,0.1c0,0,0.1,0,0.1,0.1c0,0,0.1,0,0.1,0h4.4 c0.1,0,0.2,0,0.3,0c0.1,0,0.2,0,0.3,0c0.1,0,0.2,0,0.3,0.1c0.1,0,0.2,0,0.3,0.1c0.1,0,0.2,0.1,0.2,0.1c0.1,0,0.2,0.1,0.2,0.1 c0.1,0,0.1,0.1,0.2,0.2c0.1,0.1,0.1,0.1,0.2,0.2c0,0.1,0.1,0.1,0.1,0.2c0,0.1,0.1,0.1,0.1,0.2c0,0.1,0.1,0.1,0.1,0.2 c0,0.1,0,0.1,0.1,0.2c0,0.1,0,0.1,0,0.2c0,0.1,0,0.2,0,0.3c0,0.1,0,0.2,0,0.3c0,0.1,0,0.2-0.1,0.3l-1.2,4.4c0,0.1,0,0.1-0.1,0.2 c0,0.1-0.1,0.2-0.1,0.2c0,0.1,0,0.1-0.1,0.2c0,0.1-0.1,0.1-0.1,0.2c-0.1,0.1-0.1,0.2-0.2,0.3c-0.1,0.1-0.1,0.2-0.2,0.3 c-0.1,0.1-0.1,0.2-0.2,0.3c-0.1,0.1-0.1,0.2-0.2,0.2c-0.1,0.1-0.3,0.3-0.5,0.4c-0.2,0.1-0.3,0.2-0.5,0.3c-0.1,0.1-0.2,0.1-0.4,0.2 c-0.1,0.1-0.2,0.1-0.4,0.1c-0.1,0-0.2,0.1-0.4,0.1c-0.1,0-0.3,0-0.4,0h-9.5l0.6-2.4H92c0,0,0.1,0,0.1,0c0,0,0.1,0,0.1,0 c0.1,0,0.1,0,0.1,0c0,0,0.1,0,0.1-0.1c0,0,0.1,0,0.1-0.1c0,0,0.1-0.1,0.1-0.1c0,0,0.1-0.1,0.1-0.1c0,0,0-0.1,0-0.1l0.3-1.3 c0,0,0-0.1,0-0.1c0,0,0-0.1,0-0.1c0,0,0-0.1-0.1-0.1c0,0,0-0.1-0.1-0.1c0,0,0,0-0.1-0.1c0,0-0.1,0-0.1-0.1c0,0-0.1,0-0.1,0 c0,0-0.1,0-0.1,0h-4.9c-0.1,0-0.2,0-0.3,0c-0.1,0-0.2,0-0.3,0s-0.2,0-0.2-0.1c-0.1,0-0.1,0-0.2-0.1c-0.1,0-0.1,0-0.2-0.1 c-0.1,0-0.1-0.1-0.2-0.1c-0.1,0-0.1-0.1-0.1-0.1c0,0-0.1-0.1-0.1-0.1c-0.1-0.1-0.1-0.2-0.2-0.3c0-0.1,0-0.1-0.1-0.2 c0-0.1,0-0.2,0-0.2c0-0.1,0-0.3,0-0.5c0-0.2,0-0.3,0.1-0.5l1.2-4.5c0-0.1,0.1-0.2,0.1-0.3c0-0.1,0.1-0.2,0.1-0.3 c0-0.1,0.1-0.2,0.1-0.3c0-0.1,0.1-0.2,0.2-0.3c0-0.1,0.1-0.2,0.2-0.3c0.1-0.1,0.1-0.2,0.2-0.3c0.1-0.1,0.1-0.2,0.2-0.2 c0.1-0.1,0.2-0.2,0.2-0.2c0.1-0.1,0.1-0.1,0.2-0.2c0.1-0.1,0.1-0.1,0.2-0.2c0.1-0.1,0.2-0.1,0.2-0.2c0.1,0,0.2-0.1,0.2-0.1 c0.1,0,0.2-0.1,0.3-0.1c0.1,0,0.2-0.1,0.3-0.1c0.1,0,0.2,0,0.3,0c0.1,0,0.2,0,0.3,0H100.2z" /> <path fill="#0583A5" d="M102.4,27.4h11.1l-0.6,2.3h-6l-0.9,3.5h5.9l-0.6,2.3h-5.9l-1,3.9h6.2l-0.6,2.3H98.6L102.4,27.4z" /> <path fill="#0583A5" d="M126.4,27.3l-0.6,2.4h-5.5c-0.1,0-0.2,0-0.3,0.1c-0.1,0-0.1,0.1-0.2,0.1c-0.1,0-0.1,0.1-0.1,0.1 c-0.1,0.1-0.2,0.2-0.2,0.2c0,0-0.1,0.1-0.1,0.1c0,0,0,0.1,0,0.1l-2.2,8.2c0,0.1,0,0.2,0,0.2c0,0,0,0.1,0,0.1c0,0,0.1,0.1,0.1,0.1 c0,0,0.1,0.1,0.1,0.1c0,0,0.1,0.1,0.1,0.1c0,0,0.1,0,0.1,0.1c0,0,0.1,0,0.1,0h5.6l-0.6,2.4h-8.5c-0.1,0-0.2,0-0.3,0 c-0.1,0-0.2,0-0.3-0.1c-0.1,0-0.2,0-0.3-0.1c-0.1,0-0.2-0.1-0.3-0.1c-0.1,0-0.2-0.1-0.2-0.1c-0.1-0.1-0.1-0.1-0.2-0.2 c-0.1-0.1-0.1-0.1-0.2-0.2c-0.1-0.1-0.1-0.2-0.1-0.3c0-0.1-0.1-0.1-0.1-0.2c0-0.1-0.1-0.2-0.1-0.3c0-0.1,0-0.2-0.1-0.3 c0-0.1,0-0.2,0-0.3c0-0.1,0-0.2,0-0.3s0-0.2,0-0.3c0-0.1,0-0.2,0.1-0.3c0-0.1,0.1-0.2,0.1-0.4l2-7.4c0-0.1,0.1-0.2,0.1-0.4 c0-0.1,0.1-0.2,0.1-0.3c0-0.1,0.1-0.2,0.2-0.3c0.1-0.1,0.1-0.2,0.2-0.3c0.1-0.1,0.1-0.2,0.2-0.3c0.1-0.1,0.2-0.2,0.2-0.3 c0.1-0.1,0.1-0.2,0.2-0.3c0.1-0.1,0.2-0.2,0.3-0.3c0.1-0.1,0.2-0.1,0.2-0.2s0.2-0.1,0.2-0.2c0.1-0.1,0.2-0.1,0.3-0.2 c0.1-0.1,0.2-0.1,0.3-0.1c0.1-0.1,0.2-0.1,0.3-0.2c0.1,0,0.2-0.1,0.3-0.1c0.1,0,0.2-0.1,0.3-0.1c0.1,0,0.2,0,0.3,0H126.4z" /> <path fill="#0583A5" d="M128.2,27.3h5l-2.9,10.8c0,0.1,0,0.1,0,0.2c0,0.1,0,0.1,0,0.2c0,0.1,0,0.1,0,0.2c0,0.1,0,0.1,0.1,0.2 c0,0.1,0.1,0.1,0.1,0.2c0,0.1,0.1,0.1,0.2,0.2c0.1,0,0.1,0.1,0.2,0.1c0.1,0,0.1,0,0.2,0h4.8c0.1,0,0.2,0,0.2,0 c0.1,0,0.1,0,0.2-0.1c0.1,0,0.1,0,0.2-0.1c0.1,0,0.1-0.1,0.2-0.1c0.1,0,0.1-0.1,0.2-0.1c0.1-0.1,0.1-0.1,0.1-0.2 c0-0.1,0.1-0.1,0.1-0.2c0-0.1,0.1-0.1,0.1-0.2l3-11.1h2.2l-2.8,10.6c0,0.1-0.1,0.2-0.1,0.3c0,0.1-0.1,0.2-0.1,0.3 c0,0.1-0.1,0.2-0.1,0.4c-0.1,0.1-0.1,0.2-0.2,0.3c0,0.1-0.1,0.2-0.2,0.3c-0.1,0.1-0.1,0.2-0.2,0.3c-0.1,0.1-0.2,0.2-0.2,0.3 c-0.1,0.1-0.2,0.2-0.3,0.3c-0.1,0.1-0.1,0.2-0.2,0.2c-0.1,0.1-0.2,0.1-0.3,0.2c-0.1,0.1-0.2,0.1-0.3,0.2c-0.1,0.1-0.2,0.1-0.3,0.2 c-0.1,0.1-0.2,0.1-0.4,0.2c-0.1,0.1-0.3,0.1-0.4,0.1c-0.1,0-0.3,0.1-0.5,0.1c-0.2,0-0.3,0-0.5,0h-7.6c-0.1,0-0.3,0-0.4,0 c-0.1,0-0.3,0-0.4-0.1c-0.1,0-0.2,0-0.3-0.1c-0.1,0-0.2-0.1-0.3-0.2c-0.1-0.1-0.2-0.1-0.2-0.2c-0.1-0.1-0.1-0.1-0.2-0.2 c-0.1-0.1-0.1-0.2-0.2-0.3c-0.1-0.1-0.1-0.2-0.1-0.3c0-0.1-0.1-0.2-0.1-0.3c0-0.1-0.1-0.2-0.1-0.3c0-0.1,0-0.2,0-0.4 c0-0.1,0-0.2,0-0.4c0-0.1,0-0.2,0-0.4c0-0.1,0-0.2,0.1-0.4c0-0.1,0-0.2,0-0.4c0-0.1,0.1-0.2,0.1-0.4L128.2,27.3z" /> <path fill="#0583A5" d="M144.1,27.4h10.8c0.3,0,0.5,0,0.7,0.1c0.2,0,0.4,0.1,0.6,0.1c0.2,0.1,0.3,0.2,0.5,0.3 c0.1,0.1,0.3,0.2,0.3,0.4c0,0.1,0.1,0.1,0.1,0.2c0,0.1,0.1,0.2,0.1,0.3c0,0.1,0,0.2,0,0.3c0,0.1,0,0.2,0,0.3c0,0.2,0,0.3-0.1,0.5 c0,0.2-0.1,0.4-0.1,0.6l-0.8,3c0,0.1-0.1,0.1-0.1,0.2c0,0.1,0,0.1-0.1,0.2c0,0.1,0,0.1-0.1,0.2c0,0.1-0.1,0.2-0.1,0.2 c0,0.1-0.1,0.1-0.1,0.2c0,0.1-0.1,0.1-0.1,0.2c0,0.1-0.1,0.1-0.2,0.2c-0.1,0.1-0.1,0.1-0.2,0.2c0,0-0.1,0.1-0.1,0.1 c-0.1,0-0.1,0.1-0.2,0.1c-0.1,0-0.1,0.1-0.2,0.1c-0.1,0-0.1,0.1-0.2,0.1c-0.1,0-0.1,0.1-0.2,0.1c-0.1,0-0.2,0-0.2,0 c-0.1,0-0.2,0-0.3,0c-0.1,0-0.2,0-0.3,0l1.2,6.2h-5.6l-0.7-6.2H147l-1.7,6.2h-5L144.1,27.4z M148.5,29.7l-0.9,3.4h3.2 c0.1,0,0.1,0,0.2,0c0,0,0.1,0,0.1,0c0,0,0.1,0,0.1-0.1c0,0,0.1-0.1,0.1-0.1c0,0,0,0,0.1-0.1c0,0,0-0.1,0.1-0.1c0,0,0-0.1,0.1-0.1 c0,0,0-0.1,0.1-0.2l0.6-2.2c0,0,0-0.1,0-0.1c0,0,0-0.1,0-0.1c0,0,0-0.1,0-0.1c0,0,0-0.1-0.1-0.1c0,0,0,0-0.1-0.1c0,0-0.1,0-0.1,0 c0,0-0.1,0-0.1,0c0,0-0.1,0-0.1,0H148.5z" /> <path fill="#0583A5" d="M160.9,27.4l5.1,0l-3.9,14.4h-5L160.9,27.4z" /> <path fill="#0583A5" d="M166.7,27.3h12.6l-0.6,2.4h-3.8l-3.2,12h-5l3.2-12H166L166.7,27.3z" /> <path fill="#0583A5" d="M182.6,36.2l-2.9-8.8h5.9l2,5.9l4.9-5.9h2.6l-7.6,9.1l-1.4,5.4h-5L182.6,36.2z" /> </g> <g> <g> <path fill="#515150" d="M207.1,31.8c0-0.1,0-0.2,0-0.3c0-0.1,0-0.2,0-0.3s0-0.2,0-0.2c0-0.1,0-0.1,0-0.2c0-0.1,0-0.1-0.1-0.2 c0,0,0-0.1-0.1-0.2c0-0.1-0.1-0.1-0.1-0.2c0,0-0.1-0.1-0.2-0.2c-0.1-0.1-0.1-0.1-0.2-0.2c-0.1,0-0.1-0.1-0.2-0.1 c-0.1,0-0.1-0.1-0.2-0.1c-0.1,0-0.2,0-0.2-0.1c-0.1,0-0.2,0-0.2-0.1c-0.1,0-0.2,0-0.2,0c-0.1,0-0.2,0-0.2,0h-8.9l-3.2,12h4.2 l1.2-4.3h4.8c0.1,0,0.2,0,0.3,0c0.1,0,0.2,0,0.3,0c0.1,0,0.2,0,0.3,0c0.1,0,0.2-0.1,0.3-0.1c0.1,0,0.1-0.1,0.2-0.1 c0.1,0,0.2-0.1,0.2-0.1c0.1,0,0.1-0.1,0.2-0.1c0.1,0,0.1-0.1,0.2-0.1c0.1,0,0.1-0.1,0.2-0.2c0.1-0.1,0.1-0.1,0.2-0.2 c0,0,0.1-0.1,0.2-0.2c0.1-0.1,0.1-0.1,0.1-0.2c0-0.1,0.1-0.1,0.1-0.2c0-0.1,0.1-0.2,0.1-0.2c0-0.1,0.1-0.2,0.1-0.3 c0-0.1,0.1-0.2,0.1-0.3l0.8-3C207.1,32,207.1,31.9,207.1,31.8z M202.8,32.1c0,0,0,0.1,0,0.1l-0.7,2.5c0,0,0,0.1,0,0.1 c0,0,0,0.1,0,0.1c0,0-0.1,0.1-0.1,0.1c0,0-0.1,0.1-0.1,0.1c0,0-0.1,0.1-0.1,0.1c0,0-0.1,0.1-0.1,0.1c0,0-0.1,0-0.1,0.1 c0,0-0.1,0-0.1,0H199l1-3.7h2.5c0,0,0.1,0,0.1,0c0,0,0.1,0,0.1,0c0,0,0,0,0.1,0.1c0,0,0,0,0.1,0.1c0,0,0,0.1,0,0.1 c0,0,0,0.1,0,0.1C202.8,32,202.8,32.1,202.8,32.1z" /> </g> <g> <path fill="#515150" d="M219,29.6l-2.5,9.2c0,0,0,0.1-0.1,0.2c0,0.1-0.1,0.1-0.1,0.2c0,0.1-0.1,0.1-0.1,0.2c-0.1,0-0.1,0.1-0.1,0.1 c0,0-0.1,0.1-0.1,0.1c-0.1,0-0.1,0.1-0.2,0.1c0,0-0.1,0-0.2,0s-0.1,0-0.2,0h-4c-0.1,0-0.1,0-0.2,0c-0.1,0-0.1,0-0.2-0.1 c0,0-0.1-0.1-0.1-0.1c0-0.1-0.1-0.1-0.1-0.1c0,0,0-0.1-0.1-0.1c0-0.1,0-0.1,0-0.2c0,0,0-0.1,0-0.2c0-0.1,0-0.1,0-0.2l2.4-9h-4.2 l-2.3,8.7c0,0.1,0,0.2-0.1,0.3c0,0.1,0,0.2,0,0.3c0,0.1,0,0.2,0,0.3c0,0.1,0,0.2,0,0.3c0,0.1,0,0.2,0,0.3c0,0.1,0,0.2,0,0.3 c0,0.1,0,0.2,0.1,0.3c0,0.1,0.1,0.2,0.1,0.3c0,0.1,0.1,0.1,0.1,0.2c0,0.1,0.1,0.1,0.1,0.2c0.1,0.1,0.1,0.1,0.2,0.2 c0.1,0.1,0.1,0.1,0.2,0.2c0.1,0,0.2,0.1,0.3,0.1c0.1,0,0.2,0.1,0.3,0.1c0.1,0,0.2,0,0.3,0.1c0.1,0,0.2,0,0.4,0h6.4 c0.1,0,0.3,0,0.4,0c0.1,0,0.3,0,0.4-0.1c0.1,0,0.2,0,0.3-0.1c0.1,0,0.2-0.1,0.3-0.1c0.1,0,0.2-0.1,0.3-0.1 c0.1-0.1,0.2-0.1,0.2-0.2c0.1,0,0.2-0.1,0.2-0.2c0.1-0.1,0.1-0.1,0.2-0.2c0.1-0.1,0.2-0.2,0.2-0.3c0.1-0.1,0.1-0.2,0.2-0.3 c0.1-0.1,0.1-0.2,0.2-0.3c0.1-0.1,0.1-0.2,0.1-0.3c0-0.1,0.1-0.2,0.1-0.3c0-0.1,0.1-0.2,0.1-0.3c0-0.1,0.1-0.2,0.1-0.3 c0-0.1,0.1-0.2,0.1-0.3l2.4-8.8H219z" /> </g> <g> <polygon fill="#515150" points="226.7,29.6 222.5,29.6 219.3,41.6 228.5,41.6 229,39.7 224.1,39.7 " /> </g> <g> <path fill="#515150" d="M242.1,35.2c0-0.1,0-0.2,0-0.2c0-0.1,0-0.1,0-0.2s0-0.1,0-0.2c0-0.1,0-0.1-0.1-0.2c0-0.1,0-0.1-0.1-0.2 c0,0,0-0.1-0.1-0.1c0-0.1-0.1-0.1-0.1-0.1c0,0-0.1-0.1-0.2-0.1c-0.1,0-0.1-0.1-0.2-0.1c-0.1,0-0.1-0.1-0.2-0.1 c-0.1,0-0.1-0.1-0.2-0.1c-0.1,0-0.1,0-0.2,0c-0.1,0-0.1,0-0.2-0.1c-0.1,0-0.2,0-0.2,0c-0.1,0-0.2,0-0.2,0h-3.7c0,0-0.1,0-0.1,0 c0,0-0.1,0-0.1-0.1c0,0,0,0-0.1-0.1c0,0,0-0.1-0.1-0.1c0,0,0,0,0-0.1c0,0,0-0.1,0-0.1c0,0,0,0,0-0.1c0,0,0,0,0-0.1l0.2-0.9 c0,0,0,0,0-0.1c0,0,0-0.1,0.1-0.1c0,0,0,0,0.1-0.1c0,0,0,0,0.1-0.1c0,0,0.1,0,0.1,0c0,0,0.1,0,0.1,0c0,0,0,0,0.1,0 c0,0,0.1,0,0.1,0h5.6l0.5-2H235c-0.1,0-0.2,0-0.2,0c-0.1,0-0.2,0-0.2,0c-0.1,0-0.1,0-0.2,0.1c-0.1,0-0.1,0-0.2,0.1 c-0.1,0-0.1,0.1-0.2,0.1c-0.1,0-0.1,0.1-0.2,0.1c-0.1,0-0.1,0.1-0.2,0.1c-0.1,0-0.1,0.1-0.2,0.2c-0.1,0.1-0.1,0.1-0.2,0.2 c-0.1,0.1-0.1,0.1-0.2,0.2c0,0.1-0.1,0.1-0.1,0.2c-0.1,0.1-0.1,0.1-0.1,0.2c0,0.1-0.1,0.1-0.1,0.2c0,0.1-0.1,0.2-0.1,0.2 c0,0.1-0.1,0.1-0.1,0.2c0,0.1,0,0.1-0.1,0.2l-1,3.8c0,0.2-0.1,0.3-0.1,0.4c0,0.1,0,0.3,0,0.4c0,0.1,0,0.1,0,0.2 c0,0.1,0,0.1,0.1,0.2c0,0.1,0.1,0.2,0.2,0.3c0,0,0.1,0.1,0.1,0.1c0,0,0.1,0.1,0.1,0.1c0,0,0.1,0,0.1,0.1c0.1,0,0.1,0.1,0.2,0.1 c0,0,0.1,0,0.2,0.1s0.1,0,0.2,0c0.1,0,0.1,0,0.2,0s0.1,0,0.2,0h4.1c0,0,0.1,0,0.1,0c0,0,0.1,0,0.1,0c0,0,0,0,0.1,0.1 c0,0,0,0,0.1,0.1c0,0,0,0,0.1,0.1c0,0,0,0,0,0.1c0,0,0,0.1,0,0.1c0,0,0,0.1,0,0.1l-0.3,1.1c0,0,0,0.1,0,0.1c0,0,0,0.1-0.1,0.1 c0,0-0.1,0-0.1,0.1c0,0-0.1,0-0.1,0.1c0,0-0.1,0-0.1,0.1c0,0-0.1,0-0.1,0c0,0-0.1,0-0.1,0c0,0-0.1,0-0.1,0h-5.6l-0.5,2h7.9 c0.1,0,0.2,0,0.3,0c0.1,0,0.2,0,0.3-0.1c0.1,0,0.2,0,0.3-0.1c0.1,0,0.2-0.1,0.3-0.1c0.2-0.1,0.3-0.2,0.4-0.3 c0.1-0.1,0.3-0.2,0.4-0.3c0-0.1,0.1-0.1,0.2-0.2c0.1-0.1,0.1-0.1,0.2-0.2s0.1-0.1,0.1-0.2c0-0.1,0.1-0.2,0.1-0.3 c0,0,0-0.1,0.1-0.2c0-0.1,0-0.1,0.1-0.2c0-0.1,0-0.1,0.1-0.2c0-0.1,0-0.1,0.1-0.2l1-3.7C242,35.4,242,35.3,242.1,35.2z" /> </g> <g> <polygon fill="#515150" points="268.4,40.3 265.8,32.6 263.9,39.6 263.1,39.6 259.5,22.6 256.9,39.9 256.8,39.6 246.5,39.7 247.4,36.4 252.3,36.4 252.8,34.5 247.9,34.5 248.7,31.6 253.7,31.6 254.2,29.6 245,29.6 241.8,41.6 255.4,41.7 257.7,48 259.8,33.9 261.4,41.7 265.4,41.7 266,39.6 266.9,42.3 271,42.3 271,40.3 " /> </g> </g> <g> <path fill="#515150" d="M14.2,25.2v-6.1h1v6.1H14.2z" /> <path fill="#515150" d="M17.5,20.9v4.3h-1v-6.1h0.8l3.5,4.4v-4.4h1v6.1H21L17.5,20.9z" /> <path fill="#515150" d="M23.1,25.2v-6.1h2.2c0.5,0,0.9,0.1,1.3,0.2c0.4,0.2,0.7,0.4,0.9,0.7c0.2,0.3,0.4,0.6,0.6,1 c0.1,0.4,0.2,0.8,0.2,1.2c0,0.5-0.1,0.9-0.2,1.3c-0.1,0.4-0.3,0.7-0.6,1c-0.3,0.3-0.6,0.5-0.9,0.6c-0.4,0.1-0.8,0.2-1.2,0.2H23.1z M27.3,22.1c0-0.3,0-0.6-0.1-0.9c-0.1-0.3-0.2-0.5-0.4-0.7c-0.2-0.2-0.4-0.3-0.6-0.4c-0.2-0.1-0.5-0.2-0.8-0.2h-1.2v4.4h1.2 c0.3,0,0.6-0.1,0.9-0.2c0.2-0.1,0.5-0.3,0.6-0.5c0.2-0.2,0.3-0.4,0.4-0.7C27.2,22.7,27.3,22.4,27.3,22.1z" /> <path fill="#515150" d="M31.8,24.4c0.3,0,0.6-0.1,0.8-0.2c0.2-0.1,0.4-0.3,0.5-0.5c0.1-0.2,0.2-0.4,0.3-0.7c0.1-0.3,0.1-0.5,0.1-0.8 v-3.1h1v3.1c0,0.4,0,0.8-0.1,1.2c-0.1,0.4-0.3,0.7-0.5,1c-0.2,0.3-0.5,0.5-0.8,0.7c-0.3,0.2-0.7,0.2-1.2,0.2 c-0.5,0-0.9-0.1-1.2-0.3c-0.3-0.2-0.6-0.4-0.8-0.7c-0.2-0.3-0.4-0.6-0.4-1c-0.1-0.4-0.1-0.7-0.1-1.1v-3.1h1v3.1 c0,0.3,0,0.6,0.1,0.8c0.1,0.3,0.1,0.5,0.3,0.7c0.1,0.2,0.3,0.4,0.5,0.5C31.2,24.3,31.5,24.4,31.8,24.4z" /> <path fill="#515150" d="M39.3,20.5c-0.1-0.1-0.1-0.1-0.2-0.2s-0.2-0.1-0.4-0.2c-0.1-0.1-0.3-0.1-0.5-0.2c-0.2,0-0.4-0.1-0.5-0.1 c-0.4,0-0.7,0.1-0.9,0.2c-0.2,0.1-0.3,0.4-0.3,0.6c0,0.1,0,0.3,0.1,0.4c0.1,0.1,0.2,0.2,0.3,0.2c0.1,0.1,0.3,0.1,0.5,0.2 c0.2,0.1,0.4,0.1,0.7,0.2c0.3,0.1,0.6,0.2,0.8,0.2c0.2,0.1,0.5,0.2,0.6,0.3c0.2,0.1,0.3,0.3,0.4,0.5c0.1,0.2,0.1,0.4,0.1,0.7 c0,0.3-0.1,0.6-0.2,0.8c-0.1,0.2-0.3,0.4-0.5,0.5c-0.2,0.1-0.4,0.2-0.7,0.3c-0.3,0.1-0.6,0.1-0.9,0.1c-0.5,0-0.9-0.1-1.3-0.2 c-0.4-0.1-0.8-0.3-1.2-0.6l0.4-0.8c0.1,0.1,0.2,0.2,0.3,0.2c0.1,0.1,0.3,0.2,0.5,0.3c0.2,0.1,0.4,0.1,0.6,0.2 c0.2,0.1,0.4,0.1,0.7,0.1c0.4,0,0.7-0.1,0.9-0.2c0.2-0.1,0.3-0.3,0.3-0.6c0-0.2,0-0.3-0.1-0.4c-0.1-0.1-0.2-0.2-0.3-0.3 c-0.1-0.1-0.3-0.1-0.5-0.2c-0.2-0.1-0.4-0.1-0.7-0.2c-0.3-0.1-0.6-0.2-0.8-0.3c-0.2-0.1-0.4-0.2-0.6-0.3c-0.1-0.1-0.3-0.3-0.3-0.4 c-0.1-0.2-0.1-0.4-0.1-0.6c0-0.3,0.1-0.6,0.2-0.8c0.1-0.2,0.3-0.4,0.5-0.6c0.2-0.2,0.4-0.3,0.7-0.4c0.3-0.1,0.6-0.1,0.9-0.1 c0.4,0,0.8,0.1,1.1,0.2c0.3,0.1,0.7,0.3,0.9,0.5L39.3,20.5z" /> <path fill="#515150" d="M45.4,19.9h-2v5.2h-1v-5.2h-2v-0.8h5V19.9z" /> <path fill="#515150" d="M46.2,25.2v-6.1h2.6c0.3,0,0.5,0.1,0.8,0.2s0.4,0.3,0.6,0.4c0.2,0.2,0.3,0.4,0.4,0.6c0.1,0.2,0.1,0.5,0.1,0.7 c0,0.2,0,0.4-0.1,0.6c-0.1,0.2-0.1,0.4-0.2,0.5c-0.1,0.2-0.2,0.3-0.4,0.4c-0.1,0.1-0.3,0.2-0.5,0.3l1.4,2.3h-1.1l-1.3-2.1h-1.4 v2.1H46.2z M47.1,22.2h1.7c0.1,0,0.3,0,0.4-0.1c0.1-0.1,0.2-0.1,0.3-0.2c0.1-0.1,0.1-0.2,0.2-0.4c0-0.1,0.1-0.3,0.1-0.4 c0-0.2,0-0.3-0.1-0.4c-0.1-0.1-0.1-0.3-0.2-0.4c-0.1-0.1-0.2-0.2-0.3-0.2c-0.1-0.1-0.2-0.1-0.4-0.1h-1.6V22.2z" /> <path fill="#515150" d="M51.8,25.2v-6.1h1v6.1H51.8z" /> <path fill="#515150" d="M56,19.1h0.8l2.4,6.1h-1l-0.6-1.7h-2.3l-0.6,1.7h-1L56,19.1z M57.4,22.8l-1-2.6l-1,2.6H57.4z" /> <path fill="#515150" d="M60,25.2v-6.1h1v5.2h3.3v0.8H60z" /> </g> </g> </svg> </a></li> </ul> <div class="siteFooter__contactInfo"> <span class="siteFooter__contactInfoAddress"> PO Box 471 </span> <span class="siteFooter__contactInfoCityStateZip"> Downers Grove, IL 60515 </span> <span class="siteFooter__contactInfoPhone">(630) 571-4070</span> <span class="siteFooter__contactInfoCopyright">Copyright 2024</span> </div> </footer> <!--googleoff: all--><div id="cookie-law-info-bar" data-nosnippet="true"><span>By using this website, you agree to our use of cookies. This may include personalization of content and ads, and traffic analytics. Review our <a target="_blank" href="/about-us/privacy-policy/">Privacy Policy</a> for more information. <a role='button' data-cli_action="accept" id="cookie_action_close_header" class="medium cli-plugin-button cli-plugin-main-button cookie_action_close_header cli_action_button wt-cli-accept-btn" style="margin:5px">ACCEPT</a></span></div><div id="cookie-law-info-again" data-nosnippet="true"><span id="cookie_hdr_showagain">Privacy & Cookies Policy</span></div><div class="cli-modal" data-nosnippet="true" id="cliSettingsPopup" tabindex="-1" role="dialog" aria-labelledby="cliSettingsPopup" aria-hidden="true"> <div class="cli-modal-dialog" role="document"> <div class="cli-modal-content cli-bar-popup"> <button type="button" class="cli-modal-close" id="cliModalClose"> <svg class="" viewBox="0 0 24 24"><path d="M19 6.41l-1.41-1.41-5.59 5.59-5.59-5.59-1.41 1.41 5.59 5.59-5.59 5.59 1.41 1.41 5.59-5.59 5.59 5.59 1.41-1.41-5.59-5.59z"></path><path d="M0 0h24v24h-24z" fill="none"></path></svg> <span class="wt-cli-sr-only">Close</span> </button> <div class="cli-modal-body"> <div class="cli-container-fluid cli-tab-container"> <div class="cli-row"> <div class="cli-col-12 cli-align-items-stretch cli-px-0"> <div class="cli-privacy-overview"> <h4>Privacy Overview</h4> <div class="cli-privacy-content"> <div class="cli-privacy-content-text">This website uses cookies to improve your experience while you navigate through the website. Out of these, the cookies that are categorized as necessary are stored on your browser as they are essential for the working of basic functionalities of the website. We also use third-party cookies that help us analyze and understand how you use this website. These cookies will be stored in your browser only with your consent. You also have the option to opt-out of these cookies. But opting out of some of these cookies may affect your browsing experience.</div> </div> <a class="cli-privacy-readmore" aria-label="Show more" role="button" data-readmore-text="Show more" data-readless-text="Show less"></a> </div> </div> <div class="cli-col-12 cli-align-items-stretch cli-px-0 cli-tab-section-container"> <div class="cli-tab-section"> <div class="cli-tab-header"> <a role="button" tabindex="0" class="cli-nav-link cli-settings-mobile" data-target="necessary" data-toggle="cli-toggle-tab"> Necessary </a> <div class="wt-cli-necessary-checkbox"> <input type="checkbox" class="cli-user-preference-checkbox" id="wt-cli-checkbox-necessary" data-id="checkbox-necessary" checked="checked" /> <label class="form-check-label" for="wt-cli-checkbox-necessary">Necessary</label> </div> <span class="cli-necessary-caption">Always Enabled</span> </div> <div class="cli-tab-content"> <div class="cli-tab-pane cli-fade" data-id="necessary"> <div class="wt-cli-cookie-description"> Necessary cookies are absolutely essential for the website to function properly. This category only includes cookies that ensures basic functionalities and security features of the website. These cookies do not store any personal information. </div> </div> </div> </div> <div class="cli-tab-section"> <div class="cli-tab-header"> <a role="button" tabindex="0" class="cli-nav-link cli-settings-mobile" data-target="non-necessary" data-toggle="cli-toggle-tab"> Non-necessary </a> <div class="cli-switch"> <input type="checkbox" id="wt-cli-checkbox-non-necessary" class="cli-user-preference-checkbox" data-id="checkbox-non-necessary" checked='checked' /> <label for="wt-cli-checkbox-non-necessary" class="cli-slider" data-cli-enable="Enabled" data-cli-disable="Disabled"><span class="wt-cli-sr-only">Non-necessary</span></label> </div> </div> <div class="cli-tab-content"> <div class="cli-tab-pane cli-fade" data-id="non-necessary"> <div class="wt-cli-cookie-description"> Any cookies that may not be particularly necessary for the website to function and is used specifically to collect user personal data via analytics, ads, other embedded contents are termed as non-necessary cookies. It is mandatory to procure user consent prior to running these cookies on your website. </div> </div> </div> </div> </div> </div> </div> </div> <div class="cli-modal-footer"> <div class="wt-cli-element cli-container-fluid cli-tab-container"> <div class="cli-row"> <div class="cli-col-12 cli-align-items-stretch cli-px-0"> <div class="cli-tab-footer wt-cli-privacy-overview-actions"> <a id="wt-cli-privacy-save-btn" role="button" tabindex="0" data-cli-action="accept" class="wt-cli-privacy-btn cli_setting_save_button wt-cli-privacy-accept-btn cli-btn">SAVE & ACCEPT</a> </div> </div> </div> </div> </div> </div> </div> </div> <div class="cli-modal-backdrop cli-fade cli-settings-overlay"></div> <div class="cli-modal-backdrop cli-fade cli-popupbar-overlay"></div> <!--googleon: all--> <svg width="0" height="0" class="h5ap_svg_hidden" style="display: none;"> <symbol xmlns="http://www.w3.org/2000/svg" viewBox="0 0 511.997 511.997" id="exchange"> <path d="M467.938 87.164L387.063 5.652c-7.438-7.495-19.531-7.54-27.02-.108s-7.54 19.525-.108 27.014l67.471 68.006-67.42 67.42c-7.464 7.457-7.464 19.557 0 27.014 3.732 3.732 8.616 5.598 13.507 5.598s9.781-1.866 13.513-5.591l80.876-80.876c7.443-7.44 7.463-19.495.056-26.965z"></path> <path d="M455.005 81.509H56.995c-10.552 0-19.104 8.552-19.104 19.104v147.741c0 10.552 8.552 19.104 19.104 19.104s19.104-8.552 19.104-19.104V119.718h378.905c10.552 0 19.104-8.552 19.104-19.104.001-10.552-8.551-19.105-19.103-19.105zM83.964 411.431l67.42-67.413c7.457-7.457 7.464-19.55 0-27.014-7.463-7.464-19.563-7.464-27.02 0l-80.876 80.869c-7.444 7.438-7.47 19.493-.057 26.963l80.876 81.512a19.064 19.064 0 0013.564 5.649c4.865 0 9.731-1.847 13.456-5.54 7.489-7.432 7.54-19.525.108-27.02l-67.471-68.006z"></path> <path d="M454.368 238.166c-10.552 0-19.104 8.552-19.104 19.104v135.005H56.995c-10.552 0-19.104 8.552-19.104 19.104s8.552 19.104 19.104 19.104h397.38c10.552 0 19.104-8.552 19.098-19.104V257.271c-.001-10.552-8.553-19.105-19.105-19.105z"></path> </symbol> </svg> <svg width="0" height="0" class="h5ap_svg_hidden" style="display: none;"> <symbol xmlns="http://www.w3.org/2000/svg" viewBox="0 0 477.88 477.88" id="shuffle"> <path d="M472.897 124.269a.892.892 0 01-.03-.031l-.017.017-68.267-68.267c-6.78-6.548-17.584-6.36-24.132.42-6.388 6.614-6.388 17.099 0 23.713l39.151 39.151h-95.334c-65.948.075-119.391 53.518-119.467 119.467-.056 47.105-38.228 85.277-85.333 85.333h-102.4C7.641 324.072 0 331.713 0 341.139s7.641 17.067 17.067 17.067h102.4c65.948-.075 119.391-53.518 119.467-119.467.056-47.105 38.228-85.277 85.333-85.333h95.334l-39.134 39.134c-6.78 6.548-6.968 17.353-.419 24.132 6.548 6.78 17.353 6.968 24.132.419.142-.137.282-.277.419-.419l68.267-68.267c6.674-6.657 6.687-17.463.031-24.136z"></path> <path d="M472.897 329.069l-.03-.03-.017.017-68.267-68.267c-6.78-6.548-17.584-6.36-24.132.42-6.388 6.614-6.388 17.099 0 23.712l39.151 39.151h-95.334a85.209 85.209 0 01-56.9-21.726c-7.081-6.222-17.864-5.525-24.086 1.555-6.14 6.988-5.553 17.605 1.319 23.874a119.28 119.28 0 0079.667 30.43h95.334l-39.134 39.134c-6.78 6.548-6.968 17.352-.42 24.132 6.548 6.78 17.352 6.968 24.132.42.142-.138.282-.277.42-.42l68.267-68.267c6.673-6.656 6.686-17.462.03-24.135zM199.134 149.702a119.28 119.28 0 00-79.667-30.43h-102.4C7.641 119.272 0 126.913 0 136.339s7.641 17.067 17.067 17.067h102.4a85.209 85.209 0 0156.9 21.726c7.081 6.222 17.864 5.525 24.086-1.555 6.14-6.989 5.553-17.606-1.319-23.875z"></path> </symbol> </svg> <script> const single_player = document.querySelectorAll(".h5ap_single_button"); single_player.forEach(item => { const audio = item.querySelector("audio"); audio.volume = 0.6; item.querySelector('.play').addEventListener("click", function () { console.log('Audio'); single_player.forEach(player => { player.querySelector("audio")?.pause(); }) setTimeout(() => { audio.currentTime = 0; audio.play(); }, 0); }); item.querySelector('.pause').style.display = 'none'; item.querySelector('.pause').addEventListener("click", function () { audio.pause(); }); audio.addEventListener("ended", () => { item.querySelector(".play").style.display = 'inline-block'; item.querySelector(".pause").style.display = 'none'; }); audio.addEventListener("pause", () => { item.querySelector(".play").style.display = 'inline-block'; item.querySelector(".pause").style.display = 'none'; }); audio.addEventListener("play", () => { item.querySelector(".play").style.display = 'none'; item.querySelector(".pause").style.display = 'inline-block'; }); }) </script> <script> cfeArticle = { restUrl: 'https://www.controleng.com/wp-json/cfe/v1/comments/', postId: 26790 } </script> <script id="cfe-comment-template" type="text/template"> <div class="comment__meta"> <div class="comment__author">{{author}}</div> <div class="comment__datetime">{{date}}</div> </div> <div class="comment__content">{{content}}</div> <div class="comment__actions"> <button class="comment__reply">Reply</button> </div> </script> <script id="comment-form-template" type="text/template"> <input id="replyId" value="0" type="hidden" /> <label for="commentForm">Leave Comment</label> <textarea id="commentForm" name="commentText"></textarea> <button class="submit-comment">Post Comment</button> </script> <link rel='stylesheet' id='omeda_css-css' href='https://olytics.omeda.com/olytics/css/v3/p/olytics.css?ver=1' type='text/css' media='all' /> <script type="text/javascript" id="frontend-js-extra"> /* <![CDATA[ */ var CFESettings = {"zones":{"mobile":{"300x400":{"description":"300x400 Mobile (9513)","zoneid":9513},"300x250":{"description":"300x250 Mobile (Variable Zone)","zoneid":"variable","aliases":[2724,2984,2985,2721,2980,2981]},"300x250-2724":{"description":"300x250 Mobile (2724)","zoneid":2724},"300x250-2984":{"description":"300x250 Mobile (2984)","zoneid":2984},"300x250-2985":{"description":"300x250 Mobile (2985)","zoneid":2985},"300x50":{"description":"300x50 Mobile (2726)","zoneid":2726},"sslogo-mobile":{"description":"SS Logo","zoneid":3074}},"desktop":{"300x400":{"description":"300x400 (9513)","zoneid":9513},"970x250":{"description":"970x250 WC Flex","zoneid":2720},"300x600":{"description":"300x600 WC Flex (Variable Zone)","zoneid":"variable","aliases":[2723,2982,2983]},"300x600-2723":{"description":"300x600 WC Flex (2723)","zoneid":2723},"300x600-2982":{"description":"300x600 WC Flex (2982)","zoneid":2982},"300x600-2983":{"description":"300x600 WC Flex (2983)","zoneid":2983},"300x250":{"description":"300x250 (Variable Zone)","zoneid":"variable","aliases":[2721,2980,2981]},"300x250-2721":{"description":"300x250 (2721)","zoneid":2721},"300x250-2980":{"description":"300x250 (2980)","zoneid":2980},"300x250-2981":{"description":"300x250 (2981)","zoneid":2981},"728x90":{"description":"728x90","zoneid":2722},"sslogo":{"description":"SS Logo","zoneid":2727}}}}; /* ]]> */ </script> <script type="text/javascript" src="https://www.controleng.com/wp-content/themes/cfemedia/dist/js/frontend.min.js?ver=20240306-2.9a" id="frontend-js"></script> </body> </html>
