Slide-on pump for multi-gas detector
The Ventis Slide-on Pump (Model VSP) is designed for gas monitors and does not require tools to attach or remove the pump
03/06/2013
The Ventis Slide-on Pump (Model VSP) is designed for gas monitors and does not require tools to attach or remove the pump. Courtesy: Industrial ScientificThe Ventis Slide-on Pump (Model VSP), available in black or safety orange, allows for convenient sampling of up to 50 feet in a wide range of applications. It is ideally suited for gas monitors for personal protection throughout the day. No tools are required to attach or remove the pump to and from the Ventis monitor. Since the pump is powered by its own battery pack, as is the Ventis, the battery packs can be easily exchanged between instruments, as needed. There are three available battery pack options including standard lithium-ion, extended runtime lithium-ion and alkaline which make the pump extremely flexible in the field.
www.indsci.com
September 2018
July/Aug
August 2018
August 2018
September 2018
