Server module
The IEC 61850 Server Module to IEC 61850 gateway allows IEDs on an IEC 61850 network to communicate with PACs on an EtherNet/IP network.
10/06/2014
The gateway's two independent Ethernet ports allow the protocols to be on different subnets. The configuration software uses IED configuration files to import complex IEC 61850 data structures. The utility enables premier integration by creating AOIs that are imported into your Logix project, using the IEC 61850 tags so users don't have to retype them.
In substation automation applications, the module enables non-smart electrical substation devices, such as transformers and switchgear, to present their data as IEC 61850 IEDs to the SCADA system.
ProSoft Technology
psft.com/Au7
September 2018
July/Aug
August 2018
August 2018
September 2018
