Sensor mounting posts, clamps
Posts with scales enable precise positioning of mounted devices and are constructed of 304 stainless steel, laser-marked with metric scale and are available in diameters from 10 to 25 mm and lengths from 100 to 300 mm. Strut post clamps are directly mountable to commonly specified photoelectric sensors.
March 1, 2010
Posts with scales enable precise positioning of mounted devices and are constructed of 304 stainless steel, laser-marked with metric scale and are available in diameters from 10 to 25 mm and lengths from 100 to 300 mm. Strut post clamps are directly mountable to commonly specified photoelectric sensors. Material choices include 304 stainless steel or 1018 carbon steel with either black oxide or electroless nickel plating.
MISUMI USA Inc. www.misumiusa.com
