Selecting a filler metal: Seven factors to consider
From matching the base material to picking the right equipment, consider the process before starting to weld.
09/10/2015
Using a filler metal that provides the appropriate mechanical and chemical properties for the job—and is able to withstand the service conditions the weld encounters—is critical. Courtesy: HobartUsing a filler metal that provides the appropriate mechanical and chemical properties for the job-and is able to withstand the service conditions the weld encounters—is critical. It helps minimize the risk of cracking, corrosion, and/or weld defects that could lead to time-consuming and costly rework.
There are seven key factors to consider when selecting a filler metal: The base material to be welded, the welding position, regulatory specifications and codes, design requirements, shielding gas, post-weld heat treatment, and welding equipment.Below is a detailed look at each of these factors and how they dictate which filler metal to use.
Factor No. 1: The base material to be welded
Joining together two materials is, for the most part, a matter of chemistry: Which filler metal best matches the base material? If the chemistry of the materials matches, the mechanical properties (such as the tensile and yield strength) will also match. Welding operators can rest assured that their weld deposit will have the same strength and properties as the base material.
When materials being joined are not the same strength, there are other considerations. As a rule of thumb, welding operators should match the strength of the filler metal to the lower strength of the two base materials. During the welding process, dilution from the higher-strength base material is sufficient to strengthen the weld metal deposit.
Most base metals can easily be identified through tests based on appearance and reactions to magnets, fracture, chisel, and flames or sparks; and a welding operator typically knows what base material he or she is working with. In some cases—usually during repair or rework welding—it may be necessary to take a sample to a lab that can conduct a chemical analysis.
Factor No. 2: The welding position
Whenever possible, welding operators should rotate the part so it can be welded in a flat position. Welding in a flat position is always the most economical method, followed by horizontal or vertical and, lastly, an overhead position.
If a welding operator must work with a large weld that can't be manipulated, however, it forces the need to weld in multiple welding positions. Out-of-position welding can be especially challenging if there is only one wire size available. For example, a vertical weld-up using a 3/32-in.-diameter wire may be extremely difficult or even impossible. A better choice would be a wire ranging from .045 in. to 1/16-in. in diameter, but it would require setting up an additional wire feeder or another power source for the job. It would also require a change in feed rolls and, potentially, the welding gun. Companies should keep in mind that changing welding positions can slow the process and compromise efficiency, and, when possible, select a filler metal type and size that will allow for the most versatility.
Factor No. 3: Regulatory specifications and codes
Job specifications often dictate what class of wire to use. If not, welding operators should carefully consider the service requirements the welds may encounter.
For example, if a welding operator uses a mild steel filler metal for applications exposed to harsh elements, it is likely that the welds will rust, deteriorate, and corrode at a faster rate than the base material. This action could lead to weld failures, especially if the end product is of critical importance, such as a pressure vessel used in high-temperature environments or a bridge that will be exposed to the elements.
In the end, whatever filler metal a welding operator uses must also meet the service condition of the final product so that the weld deposit lasts as long as the base material. It's equally important when welding to code that the filler metal should meet the qualifications or certification of that code.
Factor No. 4: Design requirements
In addition to following codes (when required), it is important to select a filler metal that meets or exceeds the needs of a joint design, as specified by the engineer's welding configuration. For instance, when welding on thin material, it is important that the arc characteristics are appropriate—a wire that provides deep penetration may cause the welding operator to burn through. On the other hand, if the part to be welded is thick and features a single "V" joint, a filler metal with better penetration characteristics allows for better tie-in at the root and sides.
Factor No. 5: Shielding gas
It's important to ensure the filler metal and shielding gas used for an application are compatible.
Different shielding gases have different effects on filler metal. For example, the addition of argon to carbon dioxide(CO2) allows the welding operator to transfer more of the filler metal's chemistry into the weld deposit. This mixture provides consistent weld quality, offers good weld pool control, and generates lower levels of spatter. However, by transferring a richer chemistry from the filler metal into the weld deposit, it also increases the risk of potential cracking.
Conversely, using CO2 (an oxidizing gas) burns off some of the filler metal elements. One-hundred-percent CO2 offers the advantage of deep-weld penetration, which is desirable when welding thicker materials. It does tend to have larger ball transfer and can create more spatter than shielding gas mixtures that are a combination of Argon and CO2.
There are wires capable of operating with both straight CO2 and an argon/CO2 mixture. Companies should consider their available gas supply and desired weld characteristics provided by each when choosing a filler metal, and make sure that the selected filler metal is compatible with the shielding gas chosen.
Factor No. 6: Post-weld heat treatment
There are certain steels and material thicknesses that must be preheated to a certain temperature before welding commences. Preheating allows the part to cool down at a slow rate to avoid weld-shrinking issues and cracking. Similarly, post-weld heat treatment (PWHT) is used to reduce the stresses and slowly lower the residual heat introduced during welding, allowing the weld joint and base materials to return to the desired properties. On materials that require PWHT, it is important to select a filler metal capable of producing welds that respond appropriately to the application of heat.
Factor No. 7: Welding equipment
The type and size of equipment being used impacts what filler metal is best for the job. Specifically, the power source needs to provide enough amperage for the diameter of wire being used for the job. In the event that there is not enough amperage it will be necessary to either change wire diameters, which could result in slower production to complete the weld, or change to a higher-capacity machine.
It's also important for the power source to offer the proper welding current for the filler metal chosen. Welding in the wrong current can lead to spatter and poor weld quality.
Determining the desired weld characteristics is equally important. Filler metals that operate on reverse polarity (electrode positive, or EP) provide great penetration, while straight-polarity (electrode negative, or EN) filler metals produce a more shallow joint penetration.
Although the effect of various elements in filler metals can be rather complex and inter-related, a review of their general properties can also help welding operators determine which filler metal is ideal for the job.
Carbon, for example, generally increases hardness, tensile strength, and wear resistance but decreases ductility, impact, and machine ability. Nickel, on the other hand, increases hardness, tensile strength, impact, and ductility but decreases the part's ability to be machined. Similarly, there are various alloying elements that have different properties to deoxidize, refine grain structures,or improve ductility. It is important for welding operators to consider the properties needed in a completed weld when making the filler metal selection.
For additional information about welding metallurgy and how to select the best filler metal, consult your local welding equipment distributor or a trusted filler metal manufacturer.
Bruce Morrett is a product manager for Hobart.
The Bottom Line:
  • Whenever possible, welding operators should rotate the part so it can be welded in a flat position. Welding in a flat position is always the most economical, followed by horizontal or vertical and, lastly, an overhead position.
  • Whatever filler metal a welding operator uses must also meet the service condition of the final product so that the weld deposit lasts as long as the base material. It's equally important when welding to code that the filler metal should meet the qualifications or certification of that code.
  • The type and size of equipment being used impacts what filler metal is best for the job. Specifically, the power source needs to provide enough amperage for the diameter of wire being used for the job.
Key Words:
At www.plantengineering.com, KEYWORD WELDING, you'll find more articles on this topic:
Balance safety, productivity and comfort when choosing a welding helmet
There are several factors to consider when choosing the proper welding helmet-some critical, some more related to personal style-but the primary objective is to ensure that the eyes and skin are protected from the hazardous by-products of the welding process: severe sparks and potentially damaging ultraviolet and infrared rays emitted by the arc.
Welding cells adapting to manufacturing changes
Creating an adaptable weld cell goes beyond just improving the physical space, but that is also a very important component. Choosing flexible and modular welding equipment is an important way that manufacturers can maximize the value and useful life of that equipment, even as needs change.
Why welding remains vital for today's manufacturers
One of the primary benefits of welding is its flexibility. Industrial plants can weld materials in one location, ship them to the facility for installation, and position them in various configurations. Flexibility is especially valuable in the repair process, as welders can crawl up in a pipe rack in a petrochemical plant, use a torch or some other cutting process to remove the bad section and make the repair. In the transportation of fuel and natural gas, repairs are time sensitive and are even made with products flowing.
October 2018
September 2018
July/Aug
October 2018
August 2018
October 2018
September 2018
