Sealed rocker switches
The KR series of sealed rocker switches is designed for applications requiring switches to have an attractive style, superior feel and high reliability. The switches are suited for applications in the marine, off-road, transportation and agriculture markets. Single and double-pole models are available in an extensive range of electrical configurations.
By Staff January 1, 2007
The KR series of sealed rocker switches is designed for applications requiring switches to have an attractive style, superior feel and high reliability. The switches are suited for applications in the marine, off-road, transportation and agriculture markets. Single and double-pole models are available in an extensive range of electrical configurations. The switch is rated up to 15 A at 12 Vdc for 10,000 cycles. The switches are available with solder-lug/quick-connect and screw terminals, and with or without a plastic barrier between terminals. Up to 10 terminals are offered to allow for multiple electrical and illumination possibilities.
APEM
www.apem.com
