Sampling conditioning unit for use in industrial applications.
The Sampling Conditioning Unit is designed for ensuring accurate emissions monitoring in industrial applications.
The Sampling Conditioning Unit is designed for ensuring accurate emissions monitoring in industrial applications such as, maintenance and tuning of boilers, burners, engines, furnaces, turbines, kilns, incinerators, and other industrial combustion processes requiring accurate low NOx or SOx measurements. The unit is mounted right at the sampling probe exit before the sampling hose, where the water can condense and separate immediately from the gas, which minimizes any contact of the target gases with the liquid.
E-Instruments
www.E-Inst.com
