Safety labeling program
Visually Instructive Plant (VIP) program helps in creating an organized and consistent program to make a plant safer.
Visually Instructive Plant (VIP) program helps in creating an organized and consistent program to make a plant safer. The program pinpoints the areas in a plant where signs, labels, and tags are necessary; and indicates the best placement on pipes, equipment, aisles, doorways, and wherever needed. An easy-to-use manual is divided into 20 sections covering many topics, in- cluding cost justification and plant assessment information. Worksheets give companies a detailed look at cost savings.
Brady Worldwide, Inc., Signmark Div.
www.bradycorp.com
Circle 318
