Rotary screw air compressor
Featuring a variable-speed drive, the 3700V rotary screw air compressor is designed for energy efficiency, noise reduction and unimpeded access to all components. Precision-ground air ends provide efficient air compression, and an integrated air inlet valve promotes higher CFM flow. Other features include insulated, lift-off panels, a low-speed, 1,800-rpm motor and a high-efficiency, low-noise ...
11/01/2006
Featuring a variable-speed drive, the 3700V rotary screw air compressor is designed for energy efficiency, noise reduction and unimpeded access to all components. Precision-ground air ends provide efficient air compression, and an integrated air inlet valve promotes higher CFM flow. Other features include insulated, lift-off panels, a low-speed, 1,800-rpm motor and a high-efficiency, low-noise centrifugal fan.
Sullair Corp. : www.sullair.com
Maintenance & Safety
