Roller bearings
Axial-radial cylindrical roller bearings can handle axial loads in either direction simultaneously with radial loads or moment loads. An L-shaped inner ring is integrated with a shaft washer, an outer ring, two thrust roller cage assemblies and a radial full complement roller row. Bore diameters range from 50 to 400 mm for the inner ring and from 120 to 500 mm for the outer ring.
08/15/2008
Axial-radial cylindrical roller bearings can handle axial loads in either direction simultaneously with radial loads or moment loads. An L-shaped inner ring is integrated with a shaft washer, an outer ring, two thrust roller cage assemblies and a radial full complement roller row. Bore diameters range from 50 to 400 mm for the inner ring and from 120 to 500 mm for the outer ring. Customized bearing solutions can be engineered to accommodate application needs.
SKF USA Inc.
www.linearmotion.skf.com
Maintenance & Safety
