Removing rivets
Problem: A riveted panel, ball joint assembly, gear motor, or similar item must be removed. Rivet removal is typically done by knocking the head off with a hammer and chisel, often resulting in damage to the surface or holes.
06/01/1999
Solution: Center punch the top of the rivet head, and drill a hole slightly smaller than the diameter down through the rivet. Since the material remaining to be sheared is now much smaller, a light hit with the hammer and chisel snaps off the rivet head.
Contributor: Ronald R. Gould, VP/Engineering, Advance Lifts, Inc., St. Charles, IL
March 2018
Jan/Feb 2018
December 2017
December 2017
Maintenance & Safety
Industrial Analytics
IIoT: Operations & IT
