Remove compressed air contaminants
SFD dryer system is designed to enhance the performance of compressed air systems. The unit features a regenerative desiccant dryer system designed to remove oil, contaminants and water. The unit's compact and integrated design allows for easy installation and requires no additional external filters.
SFD dryer system is designed to enhance the performance of compressed air systems. The unit features a regenerative desiccant dryer system designed to remove oil, contaminants and water. The unit’s compact and integrated design allows for easy installation and requires no additional external filters. Units typically use less than 10% regenerative air compared to dryers using 20% air. SKF : www.vsm.skf.com
TO VOTE, WRITE 210 ON BALLOT
For more information, write 210 on card
