Pump bearing retrofits to offer longer life
Pump bearing is a double-row, angular contact ball bearing with a machined brass cage that outperforms steel cages under marginal lubrication conditions. A 40-deg contact angle has greater thrust load capacity.
Pump bearing is a double-row, angular contact ball bearing with a machined brass cage that outperforms steel cages under marginal lubrication conditions. A 40-deg contact angle has greater thrust load capacity. The bearing can be retrofitted without pump modifications and is intended for ANSI-style and API 610 Standard, 5th Edition, pump applications. SKF USA, Inc.
