Productivity series controllers equipped with multiple communications ports
P3-550E high-performance CPU is equipped with multiple communications ports, including two USB, two Ethernet, one RS-232 and one RS-485.
AutomationDirect’s P3-550E high-performance CPU is equipped with multiple communications ports, including two USB, two Ethernet, one RS-232 and one RS-485. The system can be expanded with the P3-RS, P3-RX or P3-EX modules and local, expansion, and remote I/O are assigned preconfigured. The P3-550E CPU features 50MB user memory and incorporates a 4-line x 10-character LCD display for system alarms and information or for displaying user-defined messages. The P2-RS is a module equipped with an RJ45 Ethernet remote I/O port and two communications ports which support serial devices, as well as an additional Micro USB IN (type B) port for remote CPU programming and monitoring.
AutomationDirect
www.automationdirect.com
