Pressure transmitter
S-10 pressure transmitter precision engineered to fit most industrial pressure measurement applications
May 4, 2011
The S-10 pressure transmitter is precision engineered to fit most industrial pressure measurement applications. A wide range of electrical connection and process connection options are available to meet almost any requirement. The compact, rugged design makes these  instruments suitable for applications including hydraulics and  pneumatics, vacuum, test equipment, liquid level measurement, press control, compressor control, pump protection and numerous other processing and control operations. The S-10 features an all-welded stainless steel measuring cell for improved media compatibility. There are no internal soft sealing materials that may react with the media or deteriorate over time.
Wika Instrument Corp.
www.wika.com
Related Resources
