Pressure sensors – 2008-06-24 – 2008-06-24
The PT4300 sensor is a stainless steel pressure sensor for use in such processes as oil and gas, refrigeration, gas compression and test stands.
The PT4300 sensor is a stainless steel pressure sensor for use in such processes as oil and gas, refrigeration, gas compression and test stands. The sensors are UL/cUL 1604 (CSA 213) Class I, Div 2, Groups A, B, C and D approved for hazardous area applications. The construction of these sensors without o-rings or welds, allows them to bear pressure ranges of up to 10,000 psi with a burst pressure of up to 20,000 psi. Turck Inc.
www.turck.us
