Pressure sensors – 2008-03-14
PK pressure sensors provide switch point detection in air and inert gas applications.
PK pressure sensors provide switch point detection in air and inert gas applications. The sensors are IP 65 rated and are suitable for use in robotic and pneumatic applications. They’re available in two body styles, pico and nano, to support a range of mounting options. The sensors provide the two pressure ranges most commonly found in pneumatic applications: 29.5 to 0 in Hg and 0 to 145-psi, with 3% accuracy. The sensors also have two PNP switch points and an M8 connector.
Turck Inc.
www.turck.com
