Power Transmission
Mounted roller bearing
Dodge large-bore ISAF pillow blocks feature integral, hydraulically assisted, adapter-mounted installation and removal systems. Factory assembled, sealed and lubricated, the blocks offer automatic clearance setting without feeler gauges. Full-shaft contact reduces fretting corrosion, and lockplates keep the locknuts tight. A built-in hydraulic piston tightens the bearing on the shaft to accommodate installation; it loosens the bearing for removal. Four-bolt blocks are available from 8 inches. A ductile iron housing is standard.
Baldor : www.baldor.com
Roller bearing
The Sealmaster mounted spherical roller bearing has a double-row design for load capacity, misalignment and speed capabilities. It comes in two distinct locking systems: set-screw-lock, with bore sizes from 57/16 to 7 inches; and adapter lock, with bore sizes from 57/16 to 8 inches. The bearing's race-mounted seals accommodate
Emerson Industrial Automation : www.emersonindustrialautomation.com
