Power meter
The PM750 meter replaces analog meters and can be used for stand-alone metering applications in custom panels, switchboards, switchgear, gensets, motor control centers and UPS systems. The meter supports direct connection up to 480VAC Ph-Ph and measures power, energy and frequency, among other traits.
The PM750 meter replaces analog meters and can be used for stand-alone metering applications in custom panels, switchboards, switchgear, gensets, motor control centers and UPS systems. The meter supports direct connection up to 480VAC Ph-Ph and measures power, energy and frequency, among other traits. It comes equipped with remote monitoring and control capabilities, allowing it to diagnose and isolate impending problems, is available in a variety of configurations and has IEC 62053-21 Class-1 and IEC 62053022 Class 0.5S certification. It mounts without tools and has a mounting depth of 50 mm.
Schneider Electric
www.us.schneider-electric.com
