Portable dock lift
The Hulk Kombo Dock is designed for facilities with limited loading dock space, offering them the flexibility of a scissors lift and the efficiency of a hydraulic dock leveler. With a vertical range of up to 60 inches, the Kombo Dock is able to load and unload nearly any type of vehicle that pulls into the loading dock area. Design highlights include a hydraulic dock leveler with regenerative hydraulics, independent powered lip control, and push-button controls. The dock leveler can be equipped withEnergy Guard perimeter seal for additional energy savings.
The independent hydraulic scissors lift has a lifting capacity of up to 20,000 lbs., and enables dock-to-grade forklift access. It also includes Quick-Connect style electrical cables with NEMA 4x hand control for simple and less expensive installation.
KELLEY
www.kelleycompany.com
