Pinpoint capture expands laser microgage uses
Pinpoint adds data interface to Laser Microgage system, which allows readings from remote lasers; allowing alignment, performance of production machinery to be analyzed.
February 8, 2011
Pinpoint Laser Systems produces a data interface accessory called “Capture” for the popular Laser Microgage industrial measuring and alignment system. Capture allows operators to quickly grab measurement readings from four remote laser receivers to analyze the alignment and performance of their production machinery and industrial equipment. (For other sensor-related developments, see the Control Engineering Sensors page at https://www.controleng.com/new-products/sensors.html.)
The Pinpoint Laser Systems software is a Microsoft Windows-based application that quickly records incoming readings, displays results, allows for added control and interfaces cleanly with spreadsheets and statistical analysis packages. Measurement readings can also be stored directly in the handheld, portable Laser Microgage display and then uploaded to a PC or laptop for graphical display, analysis, printing and storage. The Laser Microgage and Capture are reportedly easy to use and highly versatile delivering a precision of 0.0001 inch (0.0025 mm) over a working range of 180 feet (55 meters).
The Laser Microgage is purportedly used throughout industry for checking the alignment of production machinery and equipment. The precise laser reference beam is allegedly ideal for checking straightness, flatness, squareness, parallelism, bore alignment and many other geometrical parameters. Pinpoint products are designed and manufactured in the United States and incorporate durable, solid metal packaging, stainless steel components and quality glass optics for years of reliable use on the factory floor. A wide assortment of accessories enables users to adapt their Laser Microgage to new applications and reduce their dependence on outside alignment contractors. Laser Microgage systems can be found in steel mills, ship yards, aircraft plants, medical applications and more.
www.pinlaser.com
– Edited by Gust Gianos, CFE Media, Control Engineering, www.controleng.com
