Photoelectric sensors enable longer sensing distances
ML100 series photoelectric sensors now feature a more powerful and brighter light spot to enable greater signal strength and longer sensing distances of up to 30 meters (98 ft).
Pepperl+Fuchs ML100 Series photoelectric sensors now come with a more powerful and brighter light spot to enable longer sensing distances of up to 30 meters (98 ft) and provide greater signal strength to reliably “see” through more contaminants that collect on the sensor lens. The new light spot also facilitates easier alignment, even to small objects or reflectors, according to the company, because its sharply defined boundaries and lack of a central black space provides a consistent detection field with no “sensing voids.” Status LEDs also are highly visible from 360 degrees, so users can quickly ascertain sensor status from further distances and various positions. Durability is provided by metal bushings that resist stripping of threads. Sensors also feature low current consumption, automatic crosstalk protection, high immunity to ambient light, and a broad temperature rating (-30° C to 60° C; -22° F to 140° F).
ML100 Series Sensors
Also from Control Engineering:
Pepperl+Fuchs acquires the proximity sensor business of Siemens;
Proximity Sensors: How to Choose, Use Them; and
Diagnostic device checks fieldbus segment operation.
– Edited by Renee R. Bassett for Control Engineering, www.controleng.com
