Panel-mount fuse holders
The 572 series panel-mount fuse holders are designed to minimize installation time using a snap-mount feature that allows the holder to be installed without tools or mounting hardware. The holders are available for use with Class CC fuses for branch circuit protection or Midget fuses for supplementary protection.
The 572 series panel-mount fuse holders are designed to minimize installation time using a snap-mount feature that allows the holder to be installed without tools or mounting hardware. The holders are available for use with Class CC fuses for branch circuit protection or Midget fuses for supplementary protection. They are also available in watertight versions for applications that require wash-downs such as food processing, as well as versions with pre-assembled wire leads.
Littelfuse : www.littelfuse.com
