Paint finishing
The paint finishing line is designed especially for architectural panels and assemblies. The line can handle component sizes up to 3x8x24 feet and is automated with integral parts dry-off and curing ovens. Lead times can be reduced as painting capacity more than doubles and material doesn’t have to be shuttled between facilities, the company claims.
The paint finishing line is designed especially for architectural panels and assemblies. The line can handle component sizes up to 3x8x24 feet and is automated with integral parts dry-off and curing ovens. Lead times can be reduced as painting capacity more than doubles and material doesn’t have to be shuttled between facilities, the company claims. The line is designed to minimize cross contamination in the oven and reduce debris in the finish. The line is approved for application of most major Kynar/Hylar based finishes, including: Duranar, Fluropon, Fluropon Classic and Sunstorm
Southern Aluminum Finishing Co.
www.saf.com
