Oil purifier
The continuous bypass compressor oil purifier is a proactive maintenance contamination control system specifically designed for oil-flooded rotary-screw air compressors. The unit installs on most compressors to continuously remove acids and ultra-fine solids. Its patent-pending Dual-Core Cartridge combines mechanical and chemical separation technologies.
11/15/2007
The continuous bypass compressor oil purifier is a proactive maintenance contamination control system specifically designed for oil-flooded rotary-screw air compressors. The unit installs on most compressors to continuously remove acids and ultra-fine solids. Its patent-pending Dual-Core Cartridge combines mechanical and chemical separation technologies. As a small slip-stream of contaminated oil flows through the cartridge, solids are removed down to 3 microns absolute. The pre-filtered oil then passes through an ion-exchange media that absorbs and neutralizes acids.
Fluid Metrics LLC : www.fluidmetrics.com
March 2018
December 2017
Maintenance & Safety
Industrial Analytics
IIoT: Operations & IT
