Oil monitor
The DIGI test cell is designed to analyze multiple oil breakdown characteristics. Capable of measuring both water in oil and total base number (TBN), the test cell provides a digital measurement for each parameter, allowing engineers to monitor the condition of the oil and immediately act when needed.The unit features an LCD display showing direct readouts in ppm, % water or TBN, built-in memory that automatically records previous test results and‘easy-clean’ touch pad controls. Non-slip twist grips ensure that it can be fully sealed when in use.
Kittiwake www.kittiwake.com
