Non-rotating mixer ideal for low-shear applications
Clean Sweep mixer design revolutionizes mixing technology by using a swinging motion instead of a rotating motion. It provides a hermetically sealed environment with no rotating seal. This unique mixer has an impeller with specially shaped blades optimized to provide global mixing throughout the vessel and is ideal for low shear, high purity mixing applications and accommodates low liquid levels.
Clean Sweep mixer design revolutionizes mixing technology by using a swinging motion instead of a rotating motion. It provides a hermetically sealed environment with no rotating seal. This unique mixer has an impeller with specially shaped blades optimized to provide global mixing throughout the vessel and is ideal for low shear, high purity mixing applications and accommodates low liquid levels. Chemineer, Inc. : www. chemineer.com
TO VOTE, WRITE 08 ON BALLOT
For more information, write 08 on card
