Non-contact infrared thermometer
The micro IR-200 non-contact infrared thermometer provides simple, quick and accurate surface temperature readings of virtually any surface.
05/23/2016
The micro IR-200 non-contact infrared thermometer provides simple, quick and accurate surface temperature readings of virtually any surface. Courtesy: RIGIDThe micro IR-200 non-contact infrared thermometer provides simple, quick and accurate surface temperature readings. It has the ability to take measurements from further away (30:1 distance-to-spot ratio compared to 20:1); higher temperature measurement (-58º to 2192 F); and having an adjustable emissivity setting to accurately measure the temperature of virtually any surface. Features of the battery-operated IR-200 include audible and visual high and low alarms to alert users of temperatures outside of ranges set; a bright backlit display that can be turned on in poorly lit areas; and tripod mount capabilities for repeatable, precise temperature measurements.
RIGID
www.RIGID.com
September 2018
July/Aug
August 2018
August 2018
September 2018
