Non-contact displacement sensing system
Kaman Precision Products' KD-2306 single-channel multi-purpose non-contact displacement sensing system is designed to act as a replacement for linear variable differential transformers (LVDTs), air gauges, dial indicators, and micrometers.
Kaman Precision Products’ KD-2306 single-channel multi-purpose non-contact displacement sensing system is designed to act as a replacement for linear variable differential transformers (LVDTs), air gauges, dial indicators, and micrometers. Ideal for applications ranging from lab work to production/process automation, the KD-2306 supports both dual and single coil sensors. Its DIN-rail mount interface makes it ideal for integration into original equipment manufacturer (OEM) equipment and industrial control applications. The KD-2306 features terminal input/output (I/O) connections, auto-synchronization of multiple channels, and analog dc and 4 to 20mA outputs. With single ended, bipolar, and differential voltage outputs, the KD-2306 offers front face coarse and fine calibration controls.
– Edited by CFE Media. See more Control Engineering discrete sensor and vision products.
