Multifast connectors
Molded M27 multifast 26- and 28-pin connectors provide power and signals to factory automation equipment in the automotive, semiconductor and material handling industries. The cordsets and receptacles are suitable replacements for D-Sub (DB-25) style connectors in industrial settings where DB-25 connectors are limited to 30 V and low current.
By Plant Engineering Staff November 15, 2007
Molded M27 multifast 26- and 28-pin connectors provide power and signals to factory automation equipment in the automotive, semiconductor and material handling industries. The cordsets and receptacles are suitable replacements for D-Sub (DB-25) style connectors in industrial settings where DB-25 connectors are limited to 30 V and low current. The connectors are rated for 150 V and 5 A and can handle up to 18-AWG wires. The connectors also provide IEC IP 67 protection.
TURCK Inc. www.turck.com
