Multi-surface grinder
The LL2U-MS is a modular multi-surface grinding machine with extended flexibility to grind complex work pieces.
LL2U-MS multi-surface grinding machine
The LL2U-MS is a modular multi-surface grinding machine with extended flexibility to grind complex work pieces. The machine can be configured as a chucker, shoe-type centerless, roll-type centerless and center-type work (between centers). It has 10 inches of Z-axis travel; 10 inches of X axis travel; and an optional U axis, also with 10 inches of travel. All linear axes use the round hydrostatic way system with 300 degrees of bearing wrap to ensure accurate tracking in all degrees of freedom.
Bryant Grinder , div. ofVermont Machine Tool Corp.
