Multi-function I/O module
The USB-4716 is specifically designed for use in industrial environments and includes a USB connector with screw fasteners and a DIN-rail mounting kit. Drawing power directly from the USB port, it does not require an external power supply. It includes 16x single-ended (8x differential) inputs with 16-bit resolution, 200 kS/s analog inputs, 2x 16-bit analog outputs, 8x digit inputs, 8x digital o...
04/15/2007
The USB-4716 is specifically designed for use in industrial environments and includes a USB connector with screw fasteners and a DIN-rail mounting kit. Drawing power directly from the USB port, it does not require an external power supply. It includes 16x single-ended (8x differential) inputs with 16-bit resolution, 200 kS/s analog inputs, 2x 16-bit analog outputs, 8x digit inputs, 8x digital outputs and a 1x 32-bit event counter. It’s furnished with WaveScan, a trending and data logging software program.
Advantech Corporation, eAutomation Group
www.eAutomationPro.com
Advantech Corporation is a CSIA member as of 2/26/2015
November 2018
2018 Product of the Year finalists, mild steel welding: finding the right filler, and new technique joins aluminum to steel.
October 2018
September 2018
October 2018
August 2018
Summer 2018
Microgrids and universities, Steam traps and energy efficiency, Finding help with energy projects
October 2018
November 2018
Analytics quantify processes, Fieldbus networking and IIoT, Choosing the right accelerometer
