Mounted ball bearings never require relubrication
Bev Dry mounted bearings have no provision for relubrication and are designed to run longer that way. The synthetic grease used has twice the stability of standard products. Spring-loaded oil seals exclude contamination and retain synthetic lubricant.
11/01/1998
Bev Dry mounted bearings have no provision for relubrication and are designed to run longer that way. The synthetic grease used has twice the stability of standard products. Spring-loaded oil seals exclude contamination and retain synthetic lubricant. Housing styles include pillow blocks, two and four-bolt flanges, takeups, and tapped bases. Sealmaster Bearings Div., Emerson Power Transmission
September 2018
July/Aug
August 2018
August 2018
September 2018
