MOPD coils for high-pressure CO2 systems
The MOPD BJ and BX coils are designed for use with AKVH electronic expansion valves in high-pressure CO2 systems.
Danfoss’ higher maximum opening pressure differential (MOPD) UL approved BJ and BX coils are designed to be used in high-pressure CO2 systems. These coils come with a pulling force that enables larger AKVH valves to operate in CO2 systems. MOPD BJ and BX coils feature a redesigned frame and robust encapsulation for durability as well as a clip-on fastening system with an audible latch click to minimize installation time and ensure proper installation. MOPD meets North American food retail system requirements and is designed in accordance with UL 429. They also feature two electrical connections that cover standard voltage and frequency.
Danfoss
