Mobile portable compressor
The M58 mobile portable compressor is designed for demanding applications such as demolition, sandblasting, and construction.
The M58 is designed to deliver 210 cfm at 100 psig for rental houses, construction, demolition, sandblasting, repair trucks and other demanding applications. The portable compressor has a powder coated, fully weatherproofed steel cabinet built to withstand harsh conditions. It also has a single-point lifting ball for easy mounting or dismounting. The eye-level curbside instrument panel is equipped with a smart electronic controller with a protective metal cover. The 28-gallon fuel tank is designed to provide extended operation up to 10 hours. Additional features include a steel chassis, torsion bar suspension, over-sized tires and lighting package.
Kaeser
www.us.kaeser.com
