Midspan/injectors and injector kits
The BTD-CATx series products can be used with Power-over-Ethernet enabled devices, Voice-over-Internet Protocol (VoIP) telephones, wireless access points, CPE devices and IP web and surveillance cameras.
08/28/2014
The BTD-CATx series products can be used with Power-over-Ethernet enabled devices, Voice-over-Internet Protocol (VoIP) telephones, wireless access points, CPE devices and IP web and surveillance cameras.The BTD-CATx series features the same die-cast aluminum housing as the existing line, with the addition of a DIN clip mounted on the rear, which allows the injectors to be mounted to a DIN 3 rail. The midspan/injectors are available individually or in kits, with either a 48VDC / 48 Watt or 48VDC / 70 Watt power supply.The BTD-CATx series products can be used with Power-over-Ethernet enabled devices, Voice-over-Internet Protocol (VoIP) telephones, wireless access points, CPE devices and IP web and surveillance cameras. The BTD-CATx series is available for Cat5 , Cat5e , and Cat6  Ethernet applications.
L-com Global Connectivity
www.L-com.com
March 2018
December 2017
Maintenance & Safety
Industrial Analytics
IIoT: Operations & IT
