Meters measure flow parameters
VelociCalc Plus meters simultaneously measure and log temperature, humidity, differential pressure, and velocity from a thermal anemometer or Pitot tube.
03/01/1998
VelociCalc Plus meters simultaneously measure and log temperature, humidity, differential pressure, and velocity from a thermal anemometer or Pitot tube. The meter can also calculate volumetric flow rate, wet bulb temperature, dew point, heat flow, and convert between actual and standard readings.
TSI, Inc.
September 2018
July/Aug
August 2018
August 2018
September 2018
