Metal halide light increases output 40%
Uni-Form Pulse Start System provides 40% higher maintained light output in the vertical burning position, when compared to existing 400-W standard metal halide lamps.
Uni-Form Pulse Start System provides 40% higher maintained light output in the vertical burning position, when compared to existing 400-W standard metal halide lamps. The pulse-start ballast system improves lumen maintenance, controls lamp color shift, provides almost immediate illumination, and reduces ballast losses.
Advanced Lighting Technologies, Inc.
