Maintenance Tips & Tricks – 1999 – #9
Hang the sign
Problem : Ground level warning signs placed under a movable aerial work platform such as a cherry picker bucket have to be moved frequently.
Solution : Use a fishing reel to suspend a warning sign at an appropriate height. The sign moves with the bucket, and height can be quickly adjusted as needed.
Contributor : Clay Summerlin, Square D Co., Monroe, NC; 704-226-2700
List of Tips & Tricks
Plant Engineering
