Maintenance Tips & Tricks – 1999 – #15
Tapping tight places
Problem : You need to tap or chase a thread, but working space is very tight. Solution: Press a hex nut onto the square end of a standard tap, and then use a suitable wrench or ratchet setup to turn the tap. Make up a set of taps this way for your toolbox. Contributor : Carl Swanson, Rich Products Corp., Winchester, VA; 540-667-1955 List of Tips & Tricks |
Plant Engineering |
