Maintenance-free casters
Spinfinity maintenance-free casters are designed to provide strength in shock conditions and has CNC machining to host a large internal seal.
Spinfinity is a new line of heavy-duty, maintenance-free casters. Incorporated into the kingpinless construction is special CNC machining to host a large internal seal that’s made from Nitrile butadiene rubber (NBR) and is completely enclosed inside the swivel assembly. With no outside exposure, the swivel assembly is able to keep grease in and contaminants out. The top plate and inner raceway are one forged steel piece to provide strength in shock conditions.
Hamilton Caster
www.hamiltoncaster.com/spinfinity
