Long range ultrasonic sensors with flexible outputs
Carlo Gavazzi launched its new Long Range UA30CAD60 Series Ultrasonic Sensors with digital and analog output configurations.
Carlo Gavazzi launched its new Long Range UA30CAD60 Series Ultrasonic Sensors with digital and analog output configurations. The new ultrasonic sensors have two output configurations. The first has two digital NPN or PNP outputs. The second has an analog output in either 4-20 mA or 0-10 V dc, as well as one digital NPN or PNP output. The two digital outputs can be set as standard switching outputs with two set points or as a window function. The analog output can be set with a positive or negative slope for both filling and emptying applications.The sensors offer sensing distances of 250 to 6000 mm (6 meters) and are available as either cabled or M12 quick-disconnect versions.
Carlo Gavazzi Inc.
– Edited by CFE Media. See more Control Engineering discrete sensor products.
