Long-nose pliers
With its long handles and nose allowing greater access to hard-to-reach areas, the company’s long-nose pliers provide holding power at the tip with minimal effort. The 45 and 90-degree bent nose pliers are designed to reach around obstructions. The pliers are hot-riveted for smooth opening and closing action, eliminating handle wobble.
With its long handles and nose allowing greater access to hard-to-reach areas, the company’s long-nose pliers provide holding power at the tip with minimal effort. The 45 and 90-degree bent nose pliers are designed to reach around obstructions. The pliers are hot-riveted for smooth opening and closing action, eliminating handle wobble. A knurled jaw design provides precise gripping and sure wrapping and looping of wire. The pliers are manufactured from custom U.S. tool steel that is forged, precision machined, hardened and tempered. Plastic-dipped yellow handles provide comfort and easy identification for end users.
Klein Tools
www.kleintools.com
