Literature Offers
02/15/2002
Air cleaner
A full-color brochure features the TM 1000 TaskMaster portable air cleaner, capable of capturing pollutants and fumes from grinding, welding, cutting, and gluing using a variety of attachments. Attachments are shown, including articulated source capture arms in various sizes, dual articulated arms, downdraft table, backdraft hood, and long reach flexible hose with hood. Micro Air Clean Air Systems microaironline.com Write 316 on PE card
Gas and equipment
Specialty Gas and Equipment Reference Guide contains 320-pp of technical and safety information, and pure and mixed specialty gases and liquids for all types of scientific, industrial, and regulatory compliance applications. Scott Specialty Gases scottgas.com Write 317 on PE card
Lubrication system
A catalog on PurgeX Centralized Lubrication Systems includes dimensions, specifications, and engineering data. Single piece piston injector systems are described in various actuation modes: electric, motor, air operated, and spray units. Oil-Rite Corporation oilrite.com Write 318 on PE card
Vacuum system
Custom designed vacuum systems for the process and power industries are discussed in a 12-p brochure. Also included are case studies explaining how low maintenance products have improved plant efficiency and saved time and money Croll-Reynolds croll.com Write 319 on PE card
Speed pump
The Medium Speed Pump (MSP) offers hydraulics designed for low-flow, high-head applications and a medium speed induction motor with variable frequency drive for optimal BEP and adaptability in a wide range of changing service conditions. The brochure notes that the MSP can be optionally designed for a horizontal end suction arrangement. Flowserve Corporation flowserve.com Write 320 on PE card
Conveyors
The Modular Plastic Belt (MPB) conveyor series is discussed in a catalog by Dorner Manufacturing. Included are product descriptions, detailed specifications and application recommendations. Dorner Manufacturing dorner.com Write 321 on PE card
Hand tools
The Cougar line of medium-duty hand tools are presented in a 16-p catalog. The line is designed for contractors and maintenance workers who don't need a premium line, but still want high-quality tools they can depend on. Wright Tool Company wrighttool.com Write 322 on PE card
Industrial lifting
An industrial lifting hardware catalog includes illustrations, product performance data, dimensional drawings, and application information. The reference manual contains information on the full line of Diamond D brand eye bolts and eye nuts, turnbuckles, rod ends, anchor shackles, wire rope fittings, hooks, chain hardware, U-bolts, tank flanges, and elevator maintenance hardware. Edward W. Daniel Co. ewdaniel.com Write 323 on PE card
Tools
More than 11,000 products and 220 premium industrial brands are covered in the Sears Industrial Catalog, which features both the Craftsman and Craftsman Professional lines. Sections on safety, maintenance, and accessories have been revised and expanded. Sears Industrial searsindustrial.sears.com Write 324 on PE card
Couplings
Elastomeric Curved Jaw couplings are the focus of a 24-p catalog from Lovejoy. The products are available in a broad selection of sizes, styles, and mountings for all types of industrial machinery. Lovejoy, Inc. lovejoy-inc.com Write 325 on PE card
Hydraulic power
Enerpac Industrial Tool product lines are showcased in the E324 hydraulic power catalog, a resource for hydraulic tool specifications, applications, and related information. More than 10,000 products are featured. Enerpac Industrial Tools enerpac.com Write 326 on PE card
Pump controller
A variable speed drive programmed specifically for centrifugal pumps, the PS100 controller protects by continually monitoring and reacting to both system and pump conditions. ITT Industries gouldspumps.com Write 327 on PE card
Protective gloves
The Productive Glove and Clothing Sourcebook provides 10 categories to help buyers find the gloves most appropriate for their applications, including cut resistant, heat resistant, and leather. Wells Lamont Corporation wellslamont.com Write 328 on PE card
Electrical products
A catalog details McGill utility and temporary lighting products, lamp changers, reels and cords, pin and sleeve devices, switches, and indicator lights EGS Electrical Group- McGill mcgillelectrical.com Write 329 on PE card
Pneumatic tools
T.C. Service details the complete line of Top Cat pneumatic tools and provides an overview of the company, its technical support, and its custom tool design and build capabilities. T.C. Service Co. tcservice.com Write 330 on PE card
Bearing isolators
INPRO/SEAL explains how bearing isolators eliminate the root cause of rotating equipment failure- moisture, dirt, and abrasives contaminating the bearing environment. The literature also includes product data, capabilities, and specifications. INPRO/SEAL Company inpro-seal.com Write 331 on PE card
Process control
Zontec Inc. expands its brochure for Synergy 2000 Statistical Control software to reflect new features in Release 4.0. Zontec Inc. zontec-spc.com Write 332 on PE card
Parts cleaning
A guide to the Omega line of ultrasonic parts cleaning systems — titled "You Don't Have to Live and Breathe Your Work" — describes systems designed for small- to medium-sized machine shops, parts manufacturers, and metal finishers. Omegasonics omegasonics.com Write 333 on PE card
Pumps
Product Range brochure covers eight series of industrial duty Internal Gear pumps, eight series of sanitary and industrial Rotary Lobe pumps, and Viking's high-pressure and composite material External Gear pumps. Viking Pump vikingpump.com Write 334 on PE card
Disaster preparedness
The Disaster Preparedness & Response catalog offers equipment for fire fighters, police, emergency medical personnel, government emergency planners, and anyone on the front lines of a disaster management situation. Products include respirators and protective clothing. Lab Safety Supply labsafety.com Write 335 on PE card
August 2018
August 2018
