Linear drives that reduce maintenance
Amacoil-Uhing linear drives are designed to clean and lubricate the drive shaft and are ideal in applications where metal clips, dust, and particulate contaminants are falling on the shaft.
By Amacoil October 21, 2015
Amacoil-Uhing linear drives are for automatic cleaning and lubrication of the drive shaft are ideal in applications where metal clips, dust, and particulate contaminants are falling on the shaft. One wiper is attached to each of the drive unit. As the drive moves back and forth, the wipers push debris to either end of the shaft. Ideal for use in dirty work environments, the shaft wipers reduce maintenance. Amacoil-Uhing linear drives are specified in machinery requiring a reciprocating or positioning linear motion component such as material handling systems, winding systems, spraying assemblies, converting equipment, and metrology machines.
Amacoil
Linear Motion Drives | Uhing Rolling Ring Linear Drive | Amacoil
– Edited by CFE Media. See more Control Engineering motor and drive products.
