Lighting panel-board
The 240V NQ panel-boards simplify installation and provide flexible interior circuit counts of up to 84 circuits.
The 240V NQ panel-boards simplify installation and provide flexible interior circuit counts of up to 84 circuits. All NQ panel-boards are designed to work with older Square D QO plug-in and QOB bolt-in circuit breakers. A number of subassembly kits are available, such as sub-feed circuit breakers and copper neutrals and grounds. NQ panel-boards are available in 11 standard enclosures and use the same trims as NF panel-boards. Square D, Schneider Electric www.us.squared.com
