Lighting control system – 2007-10-26
The Vari-Ballast Control (VBC) lighting control system maintains energy efficiency by utilizing a built-in scheduler, timer, relay, dimmer and a photocell that facilitates automatic daylight harvesting. The system features microprocessors that regulate current flow, dimming and timing controls with thermal monitoring and it provides universal input voltages ranging from 90 to 300 V, along with ...
The Vari-Ballast Control (VBC) lighting control system maintains energy efficiency by utilizing a built-in scheduler, timer, relay, dimmer and a photocell that facilitates automatic daylight harvesting. The system features microprocessors that regulate current flow, dimming and timing controls with thermal monitoring and it provides universal input voltages ranging from 90 to 300 V, along with variable output wattages from 14 to 430 W. The 6x6x4-inch unit complies with TUV/UL and FCC standards.
International Engineering Products and Consulting Corp.
www.iepc.cc
