LED light fixtures
Kickflip LED fixtures from Alumen 8A are made of recycled aluminum and are supported at both ends by rigid, rectangular cantilevered arms attached to the luminaire.
December 11, 2012
Kickflip LED light fixtures from Alumen 8A are designed for use in building lobbies, corridors, stairwells, and atriums. Kickflip uses a curved slender housing with an extruded clear acrylic lens and several slide-in options. The housing is made of 60% recycled aluminum and is 100% post-use recyclable. It is supported at both ends by rigid, rectangular cantilevered arms attached to the luminaire via connectors. The housing adjusts 180 deg to create direct or indirect upward or downward illumination. LEDs are shielded by the captive, impact-resistant extruded clear lens. The LED boards are replaceable and have built in foot-long increments up to 8 ft per unit.
Alumen 8A
www.alumen8a.com
