LED driver series for large-scale lighting systems
The HLG-320H-C series of LED drivers designed for large-scale lighting systems requiring high voltage with high power.
The HLG-320H-C series of LED drivers designed for large-scale lighting systems requiring high voltage with high power. Models within the series offer output ranges from 700 mA to 3500 mA, IP67 or IP65 ingress protection ratings, output current adjustment with a built-in potentiometer, 3 in 1 dimming function (0-10 V, 10 V PWM or resistance), DALI control, and smart timer dimming function. The series minimize current load and power consumption with a built-in active PFC function and high efficiency up to 94%. They have an operating temperature range of -40 C to 85 C with free air convention cooling.
Sunpower
