Lamp and ballast guide
Industrial lighting varies widely by environment and application. Workplaces range from control room to laboratory to warehouse. Each has its own lighting requirements.
12/01/2000
The industrial workplace environment is divided into two general categories-low bay and high bay. Areas where the luminaire is less than 20-ft above the floor are considered low bay, while areas where the luminaire is more than 20-ft above the floor are high bay. Low bay fixtures should spread light and reduce glare, while high bay units should concentrate light with a medium spread and prominent downward light component.
Luminance- also called brightness-is light emitted from a surface. It is measured in candelas per square meter. Luminance levels should be kept uniform to prevent worker eyestrain and fatigue, which could affect productivity. Also, accidents could occur when moving between areas not uniformly illuminated.
Lumen output of a lamp at approximately 100 hr of operation is known as initial lumens. The output of a lamp after it has operated for approximately 40% of its rated life is known as mean lumens.
Color temperature describes the appearance of the lamp source measured in deg Kelvin. High numbers are considered cool and blue in appearance. Low numbers are warm and red/yellow in appearance.
Color rendering index (CRI) measures on a scale of 1-100 how accurately colors appear under a certain source. The most accurate rendering is 100.
Lamp efficacy is measured in lumens per Watt and is the efficiency of the lamp. Like miles per gallon, the higher the number, the better the energy efficiency.
Ballasts
Arc discharge lamps, such as HID and fluorescent, require ballasts to establish the arc and maintain electrical current once the arc is struck. Ballasts also compensate for voltage variations.
Magnetic and electronic ballasts are available for fluorescent lighting systems. Ongoing developments in both lamps and ballasts are improving their efficiencies and extending their lives. Both translate to cost reductions in your plant.
Typical industrial facility areas
  • Production
      • Inspection
          • Warehouses
              • Offices
                  • Public areas
                      • Laboratories
                          • Clean rooms
                              • Control rooms
                                • Critical lighting parameters
                                  • Adequate lighting levels
                                      • Uniform illuminance
                                          • Vertical lighting
                                              • Glare reduction
                                                  • Balance brightness
                                                      • Appropriate color performance
                                                          • Appropriate mounting heights
                                                            • Plant Engineeringmagazine extends its appreciation to Philips Lighting and Lithonia Lighting for the use of their material in the preparation of this article.
                                                              -Jack Smith, Senior Editor, 630-320-7147, jsmith@cahners.com
                                                              &HEADLINE>HID ballast terminology&/HEADLINE>
                                                              Ballast regulation. Ability of a ballast to control lamp wattage, and therefore lamp output, when subjected to changes in line voltage.
                                                              Dip tolerance. Amount of line voltage drop a ballast can sustain before the lamp extinguishes. Usually expressed as a percentage; the higher the percentage, the better.
                                                              Ballast losses. Amount of additional energy a ballast consumes to operate the lamp (line Watts minus lamp Watts). There is usually a tradeoff between ballast losses and ballast regulation.
                                                              Constant wattage autotransformer (CWA). Lead-type regulator and the most widely used HID ballast. It offers good ballast regulation and moderate ballast losses. CWA is available for metal halide and high-pressure sodium lamps.
                                                              SCWA. Pulse-start version of the CWA ballast, but with greater lumen capabilities. Use on pulse-start metal halide lamps only.
                                                              LLRPSL. Low loss reactor used in areas with very little line voltage regulation. They are designed as an energy saving system. Use on pulse-start metal halide lamps only.
                                                              RLB. Regulated lag ballast (LAG-type regulator, "reg-lag") used in areas where line dip tolerance is critical. It exhibits the best ballast regulation. Use on pulse-start metal halide lamps only.
                                                              MRB. Magnetic regulated ballast referred to as a regulated or stabilized type, has operating characteristics similar to the RLB. Use on high-pressure sodium sources only.
                                                              Lighting warehouse areas
                                                              Open areasFootcandles on floor
                                                              Receipt/dispatch
                                                              Loading bays
                                                              15
                                                              Unpacking, sorting,
                                                              and control station
                                                              20
                                                              Packing and dispatch
                                                              30
                                                              Supervisor's desk
                                                              50
                                                              Open areas
                                                              Large item storage
                                                              10
                                                              Medium item storage
                                                              20
                                                              Small item storage
                                                              30
                                                              Rack areas
                                                              Footcandles on racks
                                                              Manual racks
                                                              Large item storage
                                                              10
                                                              Medium item storage
                                                              20
                                                              Small item storage
                                                              30
                                                              Self-service racks
                                                              50
                                                              Automated racks, high-rise aisles
                                                              20-50
                                                              Fluorescent lamp data
                                                              Lamp typeInitial lumensMean lumensLumen depreciationLamp life, 3 hr/startColor rendering index (CRI)Lamp efficacy,1mean lumens/W
                                                              F40 T12 Energy saving
                                                              2650
                                                              2306
                                                              0.87
                                                              20,000
                                                              60-70
                                                              65
                                                              F40 T12 Energy saving high color
                                                              2800
                                                              2520
                                                              0.90
                                                              20,000
                                                              70-80
                                                              71
                                                              F32 T8
                                                              2850
                                                              2565
                                                              0.90
                                                              20,000
                                                              75
                                                              86
                                                              F32 T8 High color
                                                              2950
                                                              2655
                                                              0.90
                                                              20,000
                                                              82-95
                                                              89
                                                              F32 T8 Long life
                                                              3000
                                                              2850
                                                              0.95
                                                              24,000
                                                              85
                                                              95
                                                              Slimline
                                                              F48 T12
                                                              2900
                                                              2610
                                                              0.90
                                                              9000
                                                              60-70
                                                              54
                                                              F48 T12 Energy saving
                                                              2400
                                                              2160
                                                              0.90
                                                              9000
                                                              62
                                                              54
                                                              F96 T12 Energy saving
                                                              5500
                                                              4950
                                                              0.90
                                                              12,000
                                                              60-70
                                                              79
                                                              F96 T8
                                                              5700
                                                              5244
                                                              0.92
                                                              15,000
                                                              75
                                                              98
                                                              F96 T8 High color
                                                              5900
                                                              5369
                                                              0.91
                                                              15,000
                                                              82-85
                                                              100
                                                              High output
                                                              F48 T12 HO
                                                              4050
                                                              3483
                                                              0.86
                                                              12,000
                                                              60-70
                                                              51
                                                              Energy saving
                                                              8000
                                                              6960
                                                              0.87
                                                              12,000
                                                              60-70
                                                              67
                                                              F96 T8 HO
                                                              8200
                                                              7626
                                                              0.93
                                                              18,000
                                                              75
                                                              95
                                                              1Based on ANSI input watts of a two-lamp ballast; T12 using magnetic ballast and T8 using electronic ballast.
                                                              F numbers refer to wattage, where an F48 lamp is rated at 48 W.
                                                              IESNA recommended lighting levels
                                                              Indoor activityAverage fc1Average lux
                                                              Assembly
                                                              Simple
                                                              30
                                                              300
                                                              Difficult
                                                              100
                                                              1000
                                                              Exacting
                                                              300--1000
                                                              3000-10,000
                                                              Raw material processing (cleaning, cutting, crushing, sorting, grading, etc.)
                                                              Course
                                                              10
                                                              100
                                                              Medium
                                                              30
                                                              300
                                                              Fine
                                                              50
                                                              500
                                                              Very fine
                                                              100
                                                              1000
                                                              Inspection
                                                              Simple
                                                              30
                                                              300
                                                              Difficult
                                                              100
                                                              1000
                                                              Exacting
                                                              300-1000
                                                              3000-10,000
                                                              Material handling
                                                              Shipping and receiving
                                                              30
                                                              300
                                                              Wrapping, packing, labeling
                                                              30
                                                              300
                                                              Picking stock and classifying
                                                              30
                                                              300
                                                              Loading (inside truck)
                                                              10
                                                              100
                                                              Machining
                                                              Rough bench or machine work
                                                              30
                                                              300
                                                              Medium bench or machine work
                                                              50
                                                              500
                                                              Fine bench or machine work
                                                              300-1000
                                                              3000-10,000
                                                              Extra-fine bench or machine work
                                                              300-1000
                                                              3000-10,000
                                                              Storage rooms or warehouses
                                                              Inactive
                                                              5
                                                              50
                                                              Active, bulky items, large labels
                                                              10
                                                              100
                                                              Active, small items, small labels
                                                              30
                                                              300
                                                              Cleanrooms
                                                              Workspace
                                                              80
                                                              800
                                                              Food processing
                                                              Workroom
                                                              30
                                                              300
                                                              Inspection areas
                                                              150
                                                              1500
                                                              Outdoor activity
                                                              Average fc, horizontal/vertical
                                                              Average lux, horizontal/vertical
                                                              Building exteriors
                                                              Active entrances
                                                              5/3
                                                              50/30
                                                              Inactive entrances (normally locked)
                                                              3/3
                                                              30/30
                                                              Building surrounds
                                                              5/3
                                                              50/30
                                                              Storage yards
                                                              Active
                                                              10/3
                                                              100/30
                                                              Inactive
                                                              1/0.3
                                                              10/3
                                                              Building and monuments, floodlighting (vertical only)
                                                              Bright surroundings, light surface
                                                              3
                                                              30
                                                              Bright surroundings, dark surface
                                                              0
                                                              100
                                                              Dark surroundings, light surface
                                                              3
                                                              30
                                                              Dark surroundings, dark surface
                                                              3
                                                              30
                                                              1Task may be horizontal, inclined, or vertical
                                                              HID lamp data
                                                              Nominal lamp wattageInitial lumensMean lumensLamp life, 10 hr/startColor rendering index (CRI)Typical startup, minTypical restrike, minLamp efficiency, means lumens/W
                                                              Metal halide - clear
                                                              175
                                                              14,000
                                                              12,000
                                                              10,000
                                                              65
                                                              2-5
                                                              10-15
                                                              69
                                                              250
                                                              22,000
                                                              17,000
                                                              10,000
                                                              65
                                                              2-5
                                                              10-15
                                                              68
                                                              400
                                                              36,000
                                                              25,000
                                                              20,000
                                                              65
                                                              2-5
                                                              10-15
                                                              63
                                                              1000
                                                              110,000
                                                              88,000
                                                              12,000
                                                              65
                                                              2-5
                                                              10-15
                                                              88
                                                              Metal halide - coated
                                                              175
                                                              14,000
                                                              10,000
                                                              10,000
                                                              70
                                                              2-5
                                                              10-15
                                                              57
                                                              250
                                                              21,500
                                                              17,000
                                                              10,000
                                                              70
                                                              2-5
                                                              10-15
                                                              68
                                                              400
                                                              36,000
                                                              25,000
                                                              20,000
                                                              70
                                                              2-5
                                                              10-15
                                                              63
                                                              1000
                                                              107,000
                                                              85,000
                                                              12,000
                                                              70
                                                              2-5
                                                              10-15
                                                              85
                                                              Metal halide high output - clear
                                                              400
                                                              44,000
                                                              34,000
                                                              20,000
                                                              65
                                                              2-5
                                                              10-15
                                                              85
                                                              Pulse start metal halide1- clear (requires special ballast and ignitor)
                                                              70
                                                              5500
                                                              4070
                                                              12,000
                                                              65
                                                              2
                                                              3-4
                                                              58
                                                              100
                                                              9000
                                                              6390
                                                              15,000
                                                              65
                                                              2
                                                              3-4
                                                              64
                                                              150
                                                              15,000
                                                              11,300
                                                              15,000
                                                              65
                                                              2
                                                              3-4
                                                              75
                                                              200
                                                              21,000
                                                              15,800
                                                              15,000
                                                              65
                                                              2
                                                              3-4
                                                              79
                                                              320
                                                              32,000
                                                              21,200
                                                              20,000
                                                              65
                                                              2
                                                              3-4
                                                              66
                                                              350
                                                              36,000
                                                              27,000
                                                              20,000
                                                              65
                                                              2
                                                              3-4
                                                              77
                                                              400
                                                              44,000
                                                              37,400
                                                              30,000
                                                              65
                                                              2
                                                              3-4
                                                              94
                                                              Pulse start metal halide1- coated (requires special ballast and ignitor)
                                                              150
                                                              14,250
                                                              10,300
                                                              15,000
                                                              70
                                                              2
                                                              3-4
                                                              69
                                                              200
                                                              20,000
                                                              14,400
                                                              15,000
                                                              70
                                                              2
                                                              3-4
                                                              72
                                                              350
                                                              34,500
                                                              24,900
                                                              20,000
                                                              70
                                                              2
                                                              3-4
                                                              71
                                                              400
                                                              42,000
                                                              35,200
                                                              30,000
                                                              70
                                                              2
                                                              3-4
                                                              88
                                                              Pulse start metal halide reg-lag1- clear (requires special reg-lag ballast and ignitor)
                                                              250
                                                              23,750
                                                              19,000
                                                              20,000
                                                              65
                                                              2
                                                              3-4
                                                              76
                                                              400
                                                              44,000
                                                              37,400
                                                              30,000
                                                              65
                                                              2
                                                              3-4
                                                              94
                                                              Pulse start metal halide reg-lag1- coated (requires special reg-lag ballast and ignitor)
                                                              250
                                                              22,600
                                                              17,500
                                                              20,000
                                                              70
                                                              2
                                                              3-4
                                                              70
                                                              400
                                                              42,000
                                                              35,200
                                                              30,000
                                                              70
                                                              2
                                                              3-4
                                                              88
                                                              High pressure sodium - clear
                                                              70
                                                              6400
                                                              5440
                                                              24,000
                                                              20-25
                                                              3-4
                                                              1-2
                                                              78
                                                              100
                                                              9500
                                                              8550
                                                              24,000
                                                              20-25
                                                              3-4
                                                              1-2
                                                              86
                                                              150
                                                              16,000
                                                              14,400
                                                              24,000
                                                              20-25
                                                              3-4
                                                              1-2
                                                              96
                                                              200
                                                              22,000
                                                              19,600
                                                              24,000
                                                              20-25
                                                              3-4
                                                              1-2
                                                              98
                                                              250
                                                              28,000
                                                              25,200
                                                              24,000
                                                              20-25
                                                              3-4
                                                              1-2
                                                              101
                                                              310
                                                              37,000
                                                              33,300
                                                              24,000
                                                              20-25
                                                              3-4
                                                              1-2
                                                              107
                                                              350
                                                              46,500
                                                              44,000
                                                              24,000
                                                              20-25
                                                              3-4
                                                              1-2
                                                              126
                                                              400
                                                              50,000
                                                              45,000
                                                              24,000
                                                              20-25
                                                              3-4
                                                              1-2
                                                              113
                                                              1000
                                                              140,000
                                                              126,000
                                                              24,000
                                                              20-25
                                                              3-4
                                                              1-2
                                                              126
                                                              High pressure sodium - coated
                                                              70
                                                              5950
                                                              5058
                                                              24,000
                                                              20-25
                                                              3-4
                                                              1-2
                                                              72
                                                              100
                                                              8800
                                                              7920
                                                              24,000
                                                              20-25
                                                              3-4
                                                              1-2
                                                              79
                                                              150
                                                              15,000
                                                              13,500
                                                              24,000
                                                              20-25
                                                              3-4
                                                              1-2
                                                              90
                                                              250
                                                              26,000
                                                              23,400
                                                              24,000
                                                              20-25
                                                              3-4
                                                              1-2
                                                              94
                                                              400
                                                              47,500
                                                              42,750
                                                              24,000
                                                              20-25
                                                              3-4
                                                              1-2
                                                              107
                                                              1High lumen, pulse start lamp/ballast system with a capacitor and internal ignitor
                                                              Ballast information for HID
                                                              Ballast typeInput WBallast regulation line voltage/line wattageBallast lossesAverage dip tolerance, %Voltages1
                                                              Metal halide
                                                              400 W CWA
                                                              458
                                                              Medium
                                                              50
                                                              120, 208, 240, 277, 347, 480
                                                              400 W SCWA
                                                              456
                                                              Medium
                                                              50
                                                              350 W SCWA
                                                              400
                                                              Medium
                                                              40
                                                              400 W LLRPSL
                                                              425
                                                              Low
                                                              25
                                                              277
                                                              350 W LLRPSL
                                                              375
                                                              Low
                                                              25
                                                              277
                                                              400 W RLB
                                                              465
                                                              High
                                                              45-50
                                                              250 W RLB
                                                              298
                                                              High
                                                              30
                                                              175 W RLB
                                                              220
                                                              High
                                                              30
                                                              400 W CWA
                                                              457
                                                              Med-high
                                                              40
                                                              250 W CWA
                                                              295
                                                              Med-high
                                                              30
                                                              400 W MRB
                                                              480
                                                              High
                                                              45
                                                              120, 208, 240, 277, 480
                                                              1Some international applications require 50-Hz equipment and different voltages. Consult ballast and lamp manufacturer.
                                                              Ballast information for fluorescent lamps
                                                              Lamp typesMagnetic T12, T8Electronic T12, T8
                                                              March 2018
                                                              December 2017
                                                              Maintenance & Safety
                                                              Industrial Analytics
                                                              IIoT: Operations & IT
                                                              Typical lumens/W with T8 lamps (4-ft length)
                                                              72
                                                              86
                                                              Operating frequency
                                                              60 Hz
                                                              20-25 kHz
                                                              Causes stroboscopic effect
                                                              Yes, moderate
                                                              No
                                                              Sound rating
                                                              A-D
                                                              A+
                                                              Operating temperature ratio
                                                              Base
